Question about Garden
Instructions to dewinterize or to start pump on in ground pool
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I have the Pentair AT 251501 in-ground pool pump.
Yes, but not recommended. If you are going to use it on an above ground pump the system head will drop to a very low number and the pump will operate very high on its pump curve causing a couple of potential problems.
First, your filter will have to be rated for the high flow. I do not have Aqua Tools curves or numbers to give you an exact figure but if you have your horsepower you can look it up on the web. Your filter needs to be rated that high or you will have problems; even a filter failure.
Your pump will exceed the hose flow ratings and may require PVC plumbing to operate.
You should consider plumbing in a throttling valve on the pump discharge to help moderate these problems.
Posted on Dec 14, 2009
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
We got a above ground salt water pool an it's turning a little green what would be the best thing to put in it.
The first thing to do is to shock it with vinyl to about 10 ppm. This should start the progress to blue. Follow the Intex instructions to make sure the pool contains the correct amount of salt and stabilizer. The pump, filter and chlorinator should be run continuously until the water has clarified. The chlorine should then be kept between 2 and 4 ppm. One last suggestion, the filter gets plugged more quickly when you have shocked the pool to get rid of algae so make sure you clean the filter to keep the flow up. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
We recently purchased the intex saltwater system for our above ground pool. We read all the instructions and followed them however our water is still cloudy and a light shade of green. what can we do
You need a sequestering agent to remove the metal from your water ... let the chlorine go to nothing ... put in some 'metal out' or similar according to the instructions on the container ... then start again with the chlorine.
Chlorine and copper and/or iron = green water
Thanks for your interest in FixYa.com
Jun 25, 2010 | Intex Automatic Salt Water System for ...
How to set up a d2000 automatic pool vacuum
Here is a copy of the users manual for these above ground pool cleaners. It has detailed instructions and pictures for set up. This should help.
http://www.backyardcitypools.com/images/BWP/Dirt-Devil-D2000-Manual.pdf
May 21, 2010 | Dirt Devil Above - Ground Auto Pool...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Hayward above ground pool pump will not start.
sounds like the windings in the motor are shot! but does it have a capacitor? if it does you could simply have a bad starting capacitor so don't let it hum for that will surely scar the windings
May 31, 2009 | Hayward Pool Products Economy 1 Hp Above...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
