Question about Tetra Green Free Uv - 2 Clarifier - 18 Watts
Can you clean the clear tube that seperates the UV bulb from the water in a Tetra Green 2 UV?
  • 56 Answers
A test tube brush or a small bottle brush will fit and not damage anything. Alternatively as long as it is not used for saltwater soak in a bucket of 5 gallons water and a 1/2 cup of bleach will kill and separate any algae. Just rinse thoroughly to flush out any leftovers and to clear the unit.
Posted on Apr 12, 2011
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
How do i go about replacing the uv light
obtain proper replacement bulb
shut down entire filter for a moment before unscrewing the top locking ring off Uv filter (left turn) lift top off set asside
using a soft clean rag retract uv tube from its cylinder holder inside , remove power connector from tube end (you should have already removed all power from converter box) with extremely clean rag handle new tube ( allow no forign material to touch outside of tube ) reinsert power connector onto new tube (same way it came off old one) then reinsert tube into holder sleeve , route power cord to proper places away from lid , replace lid and install lock ring back with enough force to ensure a leak proof seal , re start pump ck for leaks if none found then restart power converter for Uv filter
Jun 05, 2015 | Sunterra 300207 Pond UV BioFilter 2000...
What is skunked beer?
This term is often used to refer to spoiled beer; however this is not the case. Beer becomes skunked when it is unintentionally exposed to a lot of light (specifically UV radiation). Basically what happens is the light causes the hops to break down with other chemicals ultimately creating a substance which produces a very strong and pungent sulfur smell - thus giving it the 'skunked' term.
It is this reason why most bottled beers are manufactured in brown bottles. The beers made in either clear or green bottles are able to avoid skunking by using a hop substitute, known as a tetra-hop.
Feb 03, 2013 | Wine & Spirits
The plastic holder for the bulb in my tetra pfx-uv 12000 pressure filter has all **** burt out and it is all a seald unit and tetra do not sell spare parts for that any help please
Try to fix it by replacing the broken part with a plastic embrace to hold the pressure of the water. Use plastic PVC with tie raps.
Thanks
Jun 03, 2011 | Garden
Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you.  I guess this site won't want us to post email. The Canister is very easy to use, just DO NOT remove the metal tension seal ring.  To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing. Note:  use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture.  My 800-gallon "green" pond clears up in 7-days. Good luck!
M
Apr 12, 2009 | Garden
Blue and green bulbs look like they have sawdust in them
Tubes need to be removed from set. Take off front lens with 4 screws, then remove the glass circle. Has a gasket, becareful. Do this over a sink. The fluid is a clear anti-freeze. Clean inside with Formula 409 and paper towel. Rinse with water and dry. There is a plastic expantion chamber on the side. Pull that out and clean it too. Put the tube back together. Note where the wingnut was when you took it apart and oriantate the lens to go in the same way. You can use a turkey baster to refill the tube through the expantion chamber opening. Fill it up as much as possable. Put chamber back on. Put tube face down for awhile and check for leaks. That round gasket can be reused sometimes, but check it first. Then put it back together and that's it. You'll have to unplug the board on the end of tube and the ground wires. Then unplug 2 seperate plugs...one for the yoke and the other for the convergace. Make sure you mark the wires you take off and the way the tube came out. Everything must go back the same way it came out. Fluid can be purchased at MCMelectronics.com Only need to do blue and green. Red never goes bad. Do one at a time. That's about it.
Dec 22, 2008 | Philips Magnavox 51MP392H Rear Projection...
Change Clarifier Bulb
For instructions and to get a new parts breakdown you call the Tetra Pond Division in Virginia toll-free 800-526-0650 any issues getting the right info, plan B is to ask for Product Manager Curt N.
Nov 03, 2008 | Tetra Garden
Tetra Green Free Uv - 2 Clarifier - 18 Watts Logo
118 people viewed this question
Top Tetra Garden Experts
Dennis Key
Dennis Key
john h
Are you a Tetra Garden Expert? Answer questions, earn points and help others
