Question about Krups Coffee Makers & Espresso Machines
While the coffee is being expressed the filter overflows.
  • sjberg00 Apr 13, 2011
    Works! I clean the filter in the dishwasher now. Many thanks.
  • 6,993 Answers
First, make sure you're using the right type of coffee filter for your filter basket. They do come in different sizes and thicknesses. Second, make sure the coffeemaker is set to fast drip and not slow drip if it has an adjustable soak rate. Third, wash out the filter basket in your dish washer at least once a week.
If your local tap water has a lot of mineral deposits in it, it might also be good to soak the water well, basket and carafe in a product like lime-a-way overnight, then thoroughly rinse and dry everything out before using it again.
After performing the above task, please keep me posted.
Good luck.
Posted on Apr 10, 2011
Overflow in basket
Steven, I think it`s not the filter or the coffee just that more water is flowing into the basket then it can process. I would try lesser quantity of water first to see if it overflows. Try first with filter only and then with coffee. And before you do all that, your machine should be under warranty and may be returnable to the store. Do that and save the trouble of fixing it.
Mar 22, 2014 | Black & Decker CM1050B
Bloomfield coffee maker overflows, even with plain filter
The outlet of the cone filter holder is clogged. Normally its just a hole you can clean out but some units have a valve that is pushed up/open by your coffee pot. That valve may be clogged or if you changed the coffee pot it may not be opening due to the different pot. Clean valve or just remove it so the coffee will run into coffee pot.
Nov 13, 2013 | Lands Phones
Overflowing coffee maker
could be using incorrect filters for a different coffee maker, sorry if this sounds obvious but this is the first thing i would think it was unless the water flow is adjustable and coming through quicker than the filter can drain it through
Apr 29, 2013 | Cuisinart Grind and Brew 12-Cup Coffee...
COFFEE MACHINE KEEPS FIL;LING UP AND OVERFLOWS. tHIS IS A BUNNOMATIC MODEL STPF-15
Dunkin Donuts decaf coffee clogs the filter as the water fills the basket causing the basket to overflow. The coffee is ground too fine. Swtich brands or use a second filter to cover the coffee grounds to keep them from floating and clogging the filter.
Feb 24, 2011 | Bunn A10 Coffee Maker
My coffee filter for my Keurig, seems to overflow. Making coffee is fine with the pods, but not the filter with which you can use your own coffee... I have tried different types of grinds (ex. fine,...
I have had this same problem when all of some of the coffee is ground too fine. It needs to be the correct particle size and if it is too fine, it will clog the screen and either overflow or not flow at all. Look at the ground coffee you use and check to see if it is uniform size or there are a lot of very fine grounds mixed with the coarser sizing. Try asking a coffee shop to grind you some coffee specifically for your Keurig cassettes. Most pre-grounds drip coffees are too coarse and many grinders in the stores where you grind your own whole beans do not produce a uniform size. I have an OEM Keurig cassettee and two generic cassettes and the screens have different pore sizes, with the Keurig being finer.
Aug 24, 2017 | Keurig Elite B40 Coffee Maker
Basket with coffee and filter overflows. Why?
Grounds might be too fine or not leveled before brewing, sprayhead might be dirty and clogged.
Jul 02, 2010 | Cecilware APT100WT Coffee Maker
Coffee grounds overflow
Tressia,
An overflow can occur when using certain brands of coffee that are finer ground or using a water softener, bottled water, reverse osmosis, or filtered water. If you will call Bunn Customer Service, you can get a flow restrictor sprayhead which will eliminate this issue.
May 08, 2010 | Bunn NHB Coffee Maker
Water not filtering quick enough, basket overflows
Make sure your sprayhead is the proper one (5 hole) and in good shape. Also make sure that the hole on your filter basket has not been partially closed. This can happen if you set it on the hot warmer. As a last resort, you can slightly enlarge the hole in your filter basket.
Apr 28, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Sometimes coffee maker overflows
Do you grind your beans at home before brewing or is it ground from the store. If you grind just before brewing check her grind and compare it with yours.
Also check to see if she levels the coffee in the basket. Usually when a pot overflows it is because of the grind or the way the coffee sits in the basket.
May 21, 2009 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
280 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
