Question about Dirt Devil Hoover Uh70085 Pet Cyclonic? Upright Vacuum
I have a Hoover pet cyclonic upright model uh70085. the brush won't spin, I thought maybe the small belt was stretched, I ordered the correct replacement belt and replaced it, I still have slack and the brush won't turn. the floor and brush adjustment seems to be working correctly. Thanks, Tom
  • 97 Answers
SOURCE: Hoover wind tunnel cyclonic U5780900
Well, the V belt is normally fairly slack until the handle is dropped below 45 degrees, which is when the belt tensioner assembly drops into place. If turning the brushroll by hand when the vacuum is in this position fails to rotate the self propel pulley, the tensioner is not functioning properly and will need to be replaced.
Also ensure that the brushroll can spin freely by hand, as these have a tendency to melt at the ends and seize the brushroll. I have also seen the groove that the v belt fits into melt itself out of round, which can cause the same symptom as you're describing.
Keep in mind as well that while the rubber belt may appear to be ok, it does have to be replaced every 3-6 months whether it breaks or not. Even though it hasn't broken, if you were to hold it up against a new belt, you would see that the old one has stretched significantly: which can decrease the machine's ability to rotate the self-propel transmission pulley and, in turn; the brushroll.
Feel free to contact me with any further questions.
-R
Posted on Oct 02, 2008
galati2k
  • 281 Answers
SOURCE: just bought a hoover upright windtunnel cylonic weird noise
no, brush roller shouldn't be touching anything,its under warrenty so take it to a hoover repair shop with your proof of purchase and they will fix it at no cost to you.something like that they might be able to fix it while your there because it won't take long. please leave feedback
Posted on May 05, 2009
  • 50 Answers
SOURCE: My vacuum's cyclonic action is not spinning and
The following filter in your in your dump cup needs to be replaced.
F24 Dirt Devil "I" Bagless Upright Vacuum Replacement Filter Style F24 Part Number 2LT0360000
Posted on Apr 14, 2010
  • 357 Answers
SOURCE: dirt devil vacuum cleaner--trouble vacuuming dirt
Try replacing the belt. Rubber belts stretch out after about a year.
Posted on May 01, 2010
VacuumRepair
  • 438 Answers
SOURCE: Brush bar can't spin
Hi There,
Actually I just answered a question almost identical to yours! The belt on his model continiously snapped also.
I walked him through how to check the problem, and he was able to get his vacuum fixed. It really sounds to me like your brush roller has gone bad as well.
How to Replace the belt & Roller brush on a Dirt Devil Featherlite:
http://www.fixya.com/support/t4672507-eats_belts_immediately
Also here, another link to the exact roller brush that your model take on our website if you haven't already purchased one.
http://www.govacuum.com/rdd380.html
I hope this helped your your vacuum!
Chris Jones
GoVacuum.com
Here's the link:
http://www.dirtdevil.com/manuals/?id=5a3b999e-1922-401c-a419-69d2e2d13c78
Posted on May 12, 2010
Testimonial: "So grateful for your help!!!"
How do i know if the belt needs to be replaced in my hoover spin scrub
Remove the brush cover. Check belt for cuts or stressed areas.
Is the belt taut or stretched to the point of being loose. If you see
any of this replace with the correct size. Pull brush bar out of the
side slots and remove belt from motor pulley. Place new belt on
pulley and onto grooved area on the bar....stretch forward and
push back down into side slots. Remember....groove in brush bar
must line up with pulley. This is also a good time to remove hair
and other stuff from the brushes and bar.
Regards,
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brush won't rotate. belt is fine, replaced v belt but it is loose. thought the old one was stretched out but new one is the same size.
The brush spins around an "axel", try removing rotator & spray wd-40 with red straw into it. See if that works, but do NOT use on carpet until dry or you will get grease stains on carpet.
Nov 05, 2013 | Hoover WindTunnel Pet Rewind Plus, UH70086
The brush is spinning (and has been cleaned), there is a new bag, but we get no suction.
The reason the brush is not spinning is because the belt is stretched or broken. You can get a replacement belt here:
Hoover U5491-900 Belt
Jan 30, 2010 | Hoover U5491-900 Bagged Upright Vacuum
On our Hoover U6445-900 (Mach 6.9) we replaced the small belt that goes to beater brushes in front of unit. Upon starting, the Hoover quickly got hot and smoky. We shut it off and looked things over...
are you sure you purchased the right size belt..the friction you speak of is usually caused by a belt not being the right tightness or a jammed beater brush
Dec 19, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Will not cyclone any more. brush on botton will
That means that you need to replace the belt. Here is a link to the belt you need and a manual you can view with instructions:
Bissell Pet Hair Eraser Belts and Manual
Dec 08, 2009 | Bissell Upright Vacuum - The Pet Hair...
The smaller belt remains slack. the tensioner does not pull it far enough to engage. rotor brush does not spin.
the belt has been stretched, normal wear. buy a new belt, they are inexpensive, best place to getis from shop that repairs hoovers, put it in your self
Aug 15, 2009 | Hoover U5780900 Bagless Upright Cyclonic...
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt Devil Hoover Uh70085 Pet Cyclonic? Upright Vacuum Logo
97 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
