Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
On the sony dcr-hc28 i have an c32:11 error and will not allow me to insert a tape, I have tried other tapes?
  • 4,234 Answers
The C32:11 error is a motor movement error. This means that a motor or gear is NOT moving when it should. As a sfety feature, this will prevent a tape from getting loaded and getting damaged. This unit requires repair. This is not typically a DIY repair as opening these up is tricky and if not done properly can cause additional damage. Check for local labor rates as well as the fixed repair cost from Sony directly. The fixed rpair cost from Sony will also include any parts that are required.
Hope this helps,
Dan
Posted on Apr 10, 2011
Tape compartment will not close
Ummm, this means something has either cracked or come out of "socket", you may need tape.... Because there is no other way to fix it, unless a warranty is handy, you may have to tape it sorry..... Make sure everything is in correctly (all the way in).....
Jan 13, 2011 | Sony Handycam DCR-HC28 Mini DV Digital...
The tape produced by PRINT TO TAPE looks as though a striped mask were placed over it. The original images show through 3 squared areas on the screen. I used a new tape. Watching the screen while the tape...
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 05, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
I get a c31:23 error message on sony camcorder dcr-hc28. Any suggestions to fix this?
That code is telling you your heads dirty, no do not buy Shampoo just a tape head cleaner from local camera centre, all will be fine okay?
David
Jun 20, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
My sony after recording when play shows horizontal lines on screen I don't know how to fix it
either the tape or the recording head is dirty. use a new tape. if the lines are still there, get a head cleaner tape or use alcohol to clean the recording head.
Jan 31, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
My sony dcr-hc28 developed a problem where the tape will not reinsert and i get a message "re-attach power source". i re-attach, nothing changes. i remove battery, power source, re-attach, nothing...
apply a DC voltage of 5v to the tape motor at the bottom of the camcorder. you'll find two little semi-hemispheres on top of motor. trial and error to figure out which is positive.
Dec 17, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
When I put the tape in, the tape does not slide down as it is and the door close. The screen display shows C:32:11. I do not know what that means. Thank you!
The camcorder has detected an issue that may require a power reset.
To power reset,
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 02, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
I was using my dcr-h28 minidv cam yesterday and an error message stating dirty head came on the screen. So, I took a drop of alcohol on a q-tip and cleaned it up like I'd do on any other recording head......
first u buy a headcleaning tape and put it 5 second play then cheak again.the same complaint showing again u must go a repairing shop may be ur head gon .any doubt call 00971503853766
Jul 03, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Camera will not accept mini-dv tape anymore
Hello dear sir;
I have SONY handy cam(model 42E) that finger touch keys doesn’t work .what do I do now.
Please help me and send a procedure to repairing.
I am Iranian mechanical engineer.
Oct 24, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
250 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
