Question about Lexmark X6150 All-In-One InkJet Printer
Lexmark x6150 I'm using windows vista and i I cant get my my printer working, is there a full function driver for this printer yet or not? I have the one from the lexmark site but it is ****, is there anything else out there. I'm just going around in loops on this one and i just keep ending up back at the lexmark site. can someone please help me or just tell me that it is just the only one out there
  • 3 more comments
  • Nezzie Locke
    Nezzie Locke Aug 07, 2008
    Hi robee2canoby.. i have the same problem. I have a Toshiba laptop and am running Vista. According to the Lexmark site drivers are not yet available for the Lexmark X6150. So i guess its a case of wait and see... Perhaps someone out there has a suggestion regarding compatible drivers??
  • kfchelan Aug 18, 2008
    it works then it will not work after I shut the computer off
    sometimes it will print from note that runs on ansi but not nowansi
    very frustration I have a x6150
    K
  • mglsports Sep 27, 2008
    Same problem, HP w/Vista 64 bit. I've spent the past two days with HP and Lexmark online support, Lexmark support far better and more dedicated than HP. Had Lexmark techsupport remote into computer twice. Printer worked once until PC reboot, problem returns. Print job is sent to Q where it sits. Status reads as 'deleteing - printed', job doesn't print and can't be deleted. Have to turn on print spooling, delete job from sub-directory windows-sys32-spool-printers. Even the Lexmark techsupport, who I think went above and beyond the call, could not provide permanent fix. NEXT STEP - looking for new printer and considering MAC OS.
  • hoondertd Nov 23, 2008
    I have connected my X6150 to my HP laptop. The first job sent to print went great. The next job went to Q and sat while it waited for the first job to delete from the Q. It does not clear. The only way to print each job has seemed to be to restar the computer, then the job has printed from the Q. Fax and scanning won't happen at all. Help!
  • Anonymous Nov 29, 2008
    The Vista drivers available on the Lexmark website do not contain the All-In-One Center. They are minimum drivers.
    Does someone out there has a suggestion regarding compatible drivers for the all-in one??
  • 100 Answers
I had this problem also. After some research I found this was the only way to clear the cue.
Go to Control Panel > Printers > Right click on your Lexmark Printer > Select "Run as Administrator" > select "clear print cue"
It will ask you if you are sure - click yes/ok.
Your print cue will now be clear.
Trying to use task manager will not clear your print cue in the system, only the window notifying you of print cue items.
Unfortunately Vista and the Lexmark 6150 do not get along and this will probably keep happening.
Posted on Jan 13, 2010
I also have this problem. In order to get my printer to work again, I was having to reboot my system. I have not found a solution, but I have found a work around. I created a batch file that clears the print cue, but that's not enough by itself, I also have to restart the printer. It still sucks, but it sucks a little less.
The batch file I use is:
net stop spooler
del c:\windows\system32\spool\printers\*.* /Q
net start spooler
Pause
This has to be run as Admin. So I leave the batch file in my Documents folder and create a shortcut that runs as Admin.
Hope this helps.
Posted on Feb 01, 2009
Same problem as everyone else. Toshiba laptop, Vista, Lexmark x6150. Easiest thing for me is to turn printer off then back on. It deletes previous job immediately. No need to reboot. I'll remember this when it comes time to buy another printer! (and it won't be Lexmark!)
Posted on Dec 01, 2009
It worked thank you.....jersey girl
Posted on Oct 28, 2008
  • 4 Answers
Found this, don't know if it will help you though. This was 32 bit Vista Home
Making Lexmark x6150 work with Vista Home Premium After many times installing and uninstalling
Lexmark Vista Software (cjrX6100EN), the following worked for me:
Uninstall X6150 software
Go to Lexmark.com
Support
Technical support
Search the Knowledge Base
enter "X6150 Vista Driver
Click on "uninstall previous driver
message that appears during install-
ation of Windows Vista Driver".
(Click on this message even if you don't
get it)
Follow instructions that come up.
Important - Disregard the popup window
that says the driver was unsucessfully
installed.
Good luck! Posted: 09/18/2007
Posted on Aug 10, 2008
    Problem Solver:
  • 13 Answers
I encounter the same problem with my lexmark 6150.
Unplug the power first, then
What I did is just clean up the whole unit , used a vacum cleaner
clean all dirty ink stain on the roll bar and sorrounding inner case
with a solvent.
Then I spray using DW-40 to lubricate all mechanical moving parts.
When put power and tried again it works.
r_ic7
Posted on Nov 29, 2008
My impresora es modelo 4408-k02 y necesito sofware my computadora es windons 7 pero no lee la inforrmacion
Utilice el controlador de Vista en Windows 7. Antes de descargar el controlador, busque el tipo de sistema de Windows 7 (si es de 32 bits o 64 bits). En el equipo, haga clic en el menu Inicio -> PC -> Propiedades. Tome nota de el tipo de sistema. Ustedpuede descargar el controlador Lexmark X6150 de la pagina web de Lexmark utilizalos siguientes enlaces:
- Lexmark X6150 Driver para Windows Vista de 32 bits - Lexmark X6150 Driver para Vista de 64 bits
(NOTA: Esto se traduce con http://translate.google.com.)
Apr 19, 2011 | Lexmark X6150 All-In-One InkJet Printer
Tip
I need Postscript drivers for Lexmark printer T630.
Hi.
This printer supports Postscript, PPDS, and PDF emulation only on systems up to Windows 2000, on Mac OS X up to 10.6, and on Solaris.
Windows 7and Vista are not fully compatible with this printer, and the printer will not have full functionalities on this systems.
If you have Win XP, Win dows Server 2003, Win 98, Win 2000 or Mac OS, then all you have got to do is installing full factory driver software.
If you have Windows 7 or Vista, then you should upgrade the printer to get full features. Lexmark has opted for not updating this printer software. Full software release for Windows Vista and Windows 7 does not exist.
The drivers and software for this printer can be downloaded from Lexmark website, using the links below:
Lexmark_AAG_WinXP_PS_Driver- Post script driver.
System PCL Driver for Microsoft Windows XP and Server 2003
System PCL Driver for Microsoft Windows 2000.
PCL6 driver for Microsoft Windows 95, 98 and Me.
Printing solution for Mac OS X v.10.6.
Print driver for Sun Solaris 10 x86 systems.
Network print support for Linux.
Here the full driver installation procedure : How to install a Lexmark printer without the driver and software disk.
The printer may still work on Vista and Windows 7 using the built in drivers, but it will have limited functionality. See: Windows 7 Information.
Regards.
on Mar 24, 2010 | Lexmark T630 Laser Printer
Where can I find drivers for windows 7? many thanks avio
The Lexmark X6150 printer is not compatible with Windows 7 OS. However, this printer will work with Windows Vista and Windows XP computer. Here's the link for the driver - http://bit.ly/d43qMR.
Aug 17, 2010 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Have lexmark x6150,,,,,,,need driver download for vista
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Jan 27, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150
If you are using Windows Vista, then you would need to update your drivers appropriate to your OS, update Vista specifically is USB ports drivers to the latest updates/patches. This is a common issue with Vista's USB ports. Microsoft has acknowledge the issues and has posted a fix here and here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 05, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark z25 drivers for windows vista
You need to go to the Lexmark support site and A) Make sure you are using the latest driver and specifically one that works with Vista and B) If none exist then your existing driver may have become corrupted...try it again (reinstall). Tango.
Jan 14, 2008 | Computers & Internet
Lexmark X6150 All-In-One InkJet Printer Logo
1,234 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
