Question about Cell Phones
Cannot get my HS850 bluetooth to pair with my Blackberry Bold - Also cannot get the blue light to remain solid - it just flashes; the Blackberry just won't detect the device. Would appreciate any help.
I forgot my 2go password and i do not have email address two sign up with fix it
Posted on Apr 10, 2011
My samsung wep 301 will not pair with blackberry 8330. In the desktop manager, the check box to enable bluetooth support is greyed out. Windows 7 BB Desktop 5.0.1 Samsung WEP 301 Blackberry 8330 I'll take...
Please rate. This is how we (advisor/problem solvers) get people to know...we know what were doing. Thanx
1.First make sure your phone is off. Do this by pressing and holding the Multifunction button (the one that flashes blue) for 4 seconds. For "OFF" it will flash blue and red along with a series of 2 tones. Then will stop flashing. For turning "ON" hold multifunction button for 4 seconds and it will flash BLUE 4 times and 1 tone indicating it is on. It will continue to flash every 3 while in stand-by mode and every 8 seconds while on a call. 2.Set your phone in "Discover mode" make sure you look at your manual on how this is done if don't know how. Usually found under Bluetooth settings. 3.Making sure your headset if off. Press and hold the Multi-Function button until the indicator light turns solid blue (hold for approximately 8 seconds). THE MULTIFUNCTION BUTTON WILL BE LITE ONLY HALF BLUE INDICATING PAIRING MODE. 4. You phone will find and ask to pair. Press confirm/OK and enter "0000" 5.If pairing successful, light will flash blue 10x rapidly before going to flash every 3 seconds. IF UNSUCCESSFUL LIGHT WILL REMAIN ON, AND YOU WILL HAVE TO RE-ATTEMPT.
Jan 15, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
I am trying to sync a new bluetooth (sprint brand) to my blackberry curve 8330 I have bluetooth enable and have searched to locate the bluetooth earpiece and it keeps saying can't be found
You have to make sure the bluetooth is in a pairing mode for the blackberry to discover it on most bluetooth they have a pairing button turn off your bluetooth headset hold pairing button till the light is solid or flashing red and blue depending on model then search for new should find it
Sep 24, 2009 | Cell Phones
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Nextel I870 phone and my HS850 blutooth
hold down hook button until blue indicator goes solid blue
(mic FOLDED IN) flip out mic quickly and go to settins on phone and select bluetooth or connections and select find/add bluetooth device and select bond or pair enter passcode 0000.
select done and blue light should now be blinking indicating it was connected
Jan 09, 2008 | Motorola Mobility HS850 Consumer Headset
Can't get the HS850 to pair with my blackberry
Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to www.n1wireless.com
Jan 08, 2008 | Motorola Mobility HS850 Consumer Headset
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Sep 16, 2007 | Motorola Mobility HS850 Consumer Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
