I have purchased a lg ht805 dvd system and says disk error when I try to input a dvd
    Problem Solver:
  • 6 Answers
Do this
Go into the setup menu and then into the display setup and highlight the aspect ratio option, then select 16:9 wide (but do not press enter).
now quickly press the following keys in order '1','3','9','7','1','3',9 + enter . Write down all the details that the system information screen provides.
let me know the PROM OPTION CHEERS
Posted on Aug 10, 2011
My HT805VM stopped reading DVDs. It's reading VCDs, CDs and everything else.
It's EEProm is f7 00 45 b4 00 00 80 00 bb 00
Can't finthe correct code for that model.
Posted on Jul 18, 2013
I just purchased this DVD LG I'm trying to find out what channel to put it on to watch my DVDs on and I'm on DirecTV
There is usually a switch on the back of the DVD player to choose either channel 3 or 4. You will need to use the TV's remote not the direct TV remote. To change the source or input to the correct inpit mode on the remote select input then select the input mode that you plugged your DVD into ( tie. HDMI 1 or 2 ) then turn on DVD that should do it
Jul 26, 2015 | LG Televison & Video
No sound from speakers when tv is playing
Try the changing the input on your DVD to " AUX", that input will allow you to play sound from your tv through the DVD
Oct 28, 2012 | LG LHT854 Theater System
Disk error on my new LG DV582H DVD Player
Disc error can mean laser pickup assembly issues, this is clearly a manufacture defect and needs to be returned, any tampering will void the warranty.
Aug 13, 2012 | Televison & Video
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
THE DVD PLAYER DOES NOT PLAY THE DVD, IT IDENTIFIES AN ERROR CODED 80040816. PLEASES ASSIST ME
please clean the IR LASER WITH a cd disk cleaner which may be purchased at walmart for about 5 dollars. These same disks are much more expensive at radio shack. Please run the disk and allow it to clean for about 10 minutes before trying another disk again. This should do the trick for you.
Jan 20, 2011 | LG (GDR8164B) Internal DVD Drive
I lost the remote for my LG DVD receiver model number LHT754 and i cant chance the inputs
If u are trying to change the input from dvd to usb or the other inputs. All you have to do is hold down the play button on the front of the dvd home theater system until it starts to flash then press it again and keep pressing until u find the input u are looking for. It will rotate thru all inputs even the ipod input.
Sep 26, 2010 | LG LH-T754 Theater System
My home theater system plays cds but will not play dvds, what can I do to fix it, makes a scratching noise when i put dvds in it, but plays fine with a cd.
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
Jan 13, 2010 | LG LH-T754 Theater System
LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG LXD5230 System
L DVD WRITER DVD burning problem
You may try to clean you laser lens using cleansing Disk but if it wont help you. It should be echanged with LG.
Sep 28, 2009 | Computers & Internet
Televison & Video Logo
685 people viewed this question
Top Televison & Video Experts
Electro Med Services...
