Question about Roper Washing Machines
I need to replace the lid switch on my washer (model # RAS7133KQO)
  • Roper Master
  • 2,122 Answers
The part number is 3949247 and it's around 45 dollars.....copy and paste and watch the video........http://www.youtube.com/watch?v=MFsvLiuTniU.
Posted on Apr 10, 2011
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Wont agitate or drain water to spin
Check to see if your lid switch is working. On most models the lid switch will prevent the washer from spinning with lid open. Some models will stop once the washer fills with water. Depending on what brand you have depends on where the lid switch is. If you need assistance finding the lid switch or replacing it please respond back. Thank you
Aug 02, 2011 | Washing Machines
My Whirlpool washer (model LA5578XTWO) starts washing and quits
DOES THE TIMER KEEP GOING WHEN THIS HAPPENS, IF THE TIMER STOPS IT NEEDS TO BE REPLACED. DOES THE WASHER DRAIN IF YOU TURN THE TIMER MANUALLY BY HAND IF SO THE TIMER IS WORKING TO THE END OF THE WASH CYCLE AND STOPS THE TIME IS BAD
Aug 11, 2009 | Washing Machines
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer stops in the middle of the cycle, it washes but stops before draining the water to go into the spin rinse cycle. Kenmore nodle 110 serial # ce1402638 Please asvise.
This problem is commonly attributed to a lid switch malfunction. I will need a more accurate model number to confirm (located under the washer lid along the tub rim). "110" is only the beginning prefix of the model number, which identifies the manufacturer. I will need the remaining numbers to determine how the washer is configured.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
A replacement lid switch can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offer competitive pricing, so shop all three for the best price. For instructions on how to replace a lid switch, you can refer to my profile and look under my "Tips and Tricks" for links for Replacing a Lid Switch. If you still need assistance, please contact me and let me know. PS If the lid switch IS defective and you need instructions on how to by-pass it in order to drain the wash tub, let me know. In addition, if my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further.
Feb 26, 2009 | Kenmore 20172 Top Load Washer
My Kenmore 80 series washer won't agitate but it will spin. I have replaced a coupler before, but this problem seems different. Any help?
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
Feb 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine will not drain/go into spin cycle
Check your lid switch. If the lid switch is not making proper contact, or is broken, the washer will fill, agitate (some model washers won't), then just stop when it gets to the spin cycle. If this is what you are experiencing, then this could be a quick and easy repair for you.
Try opening an closing the lid. If you don't hear a clicking noise when the lid closes, the lid switch may be bad or loose. It is mounted under the opening of the tub rim on the right-hand side and held in place with two screws. Make sure the lid strike ( a small plastic piece) is present on the lid as well. This closes the switch contacts when the lid closes. If the lid switch does not function, the washer will not complete a wash cycle.
If the determine the switch and/or lid strike is broken, searspartsdirect.com carries the parts need. Just type in the model number you provided and you will find the lid switch under the "Top and Cabinet" heading as item #11 (part #3949238). The Lid Strike is under the same heading as item #20 (part #350733).
If you need advice on how to replace the lid switch please post back and let me know.
If I'm off the mark here, please post back with comments and give me a little more elaboration on what your washer is doing or not doing.
PS You do not need to drain the tub to replace the switch. If you wish to drain it, however, and want to by-pass the lid switch, I can give you instructions on how to do this as well.
Apr 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not run pump
Check your lid switch. This is a tell tale symptom of a lid switch gone bad. The washer fills, agitates, but will not spin or drain. The lid switch is located along the right hand side of the lid opening on most models, but some newer models have a switch in the left rear of the lid. Simply open and shut the lid several times and listen for a distinctive "click" of the lid switch as you open and close the lid. A lid switch usually runs about $35 to replace. If you provide me with your washer model number (usually located under the lid somewhere) I can give you the part number you need. That is...if the lid switch is the problem. The only other problem that I have encountered that caused the same symptoms, was a bad timer. Timer vs Lid Switch: Lid switch is a cheaper fix. I would try this option first. Let me know if this helps and/or if you need more guidance.
Sep 21, 2007 | Whirlpool LSR6232J Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
