Question about Toto Home
I have an low profile elongated Toto toilet and the water keeps running. How can I stop it?
  • 59 Answers
Take the lid off a check the flapper. May need a new one.
Posted on Apr 10, 2011
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
The toilet keeps running constantly - the tube in the tank is overflowing and i can not get the dripping sound to stop. Anything i can do?
The noise is because your float in the toilet is set at too high of a level and it is overflowing and making noise.
Reset your float, to adjust the water level just below the overflow pipe...this should stop your noise.
If it does not correct the problem then you will have to replace the water control unit inside of the toilet tank.
Please rate me
Dec 05, 2010 | Toto Washlet Elongated Toilet Seat Bidet
My toto power gravity siphon won't stop running. Suggestions as to how to fix would be greatly appreciated. Cheer, Mark
You have a problem with your flapper not seating all the way so the water is not filling in the tank to lift the ball **** to shut off the water first make sure the flapper is ok
Oct 24, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet bowl water keeps running eventhough flushing already finished or eventhough water in the tank already full. Model CST414M (elongated TOTO toilet). I appreciate your immediate assistance.
Look at float level, be sure that you are not running water into the overflow tube. Is the inlet valve closing? Pull the little tube that goes from the inlet valve assembly to the overflow tube and observe... Check the flapper valve for distortion, deterioration, or buildup. If anything is there, replace it.
Sep 26, 2010 | Toto Promenade, 1.6 GPF, Elongated...
My Toto Carlyle toilet with Gmax valve CONSTANTLY runs...It runs for about 3 mins, stops, then runs for 3 mins, stops, and on and on this goes!!!! I need step by step instructions on how to fix the...
Sounds like your losing water out of the tank. check to see if flapper in tank has good seal (The rubber device that fits over the whole at bottom of tank, its attached to the handle by a chain or plastic rod). Make a mark when the water shuts off to reflect the water level watch the level of water over the time you specified. If the waterline drops the you definitely have a faulty flapper. Replace with new flapper which can be purchased at most hardware stores and DIY stores like Lowe's, Menard's, Home Depote. I hope this has answered your question, please rate the answer given. Good Luck and have a great day. Jeff
Apr 04, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toto toilet is running
You will have to use ToTo OEM replacement parts. If the water is going over the overflow pipe, the fill valve washer will need to be replaced. If the water is running into the bowl and not over the overflow, the flapper will need to be replaced.
Apr 05, 2009 | Toto Drake ADA Compliant Toilet with...
Toto toilet Power Gravity intermittently running
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Mar 16, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Home Logo
87 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
