What does it mean when f-05 shows up on the display
  • yadayada
    yadayada Apr 10, 2011
    That depends on the make and the model machine.
    Brigadier General:
  • 6,277 Answers
If your washer is a Hotpoint (Indesit) 'F05' means 'Pump Block'. You did not say ;-0(
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
If this is the solution please score accordingly- thanks!
Posted on Apr 10, 2011
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/05 error code on...
The error F/05 is shown on the display due to Water Temperature Sensor Error in the washing machine.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
Can we have caller ID on the 3158-05
The Avaya 3158-05 does not have a display. It can't show the Caller ID information from the telephone provider. The Avaya 3158-07 PARTNER 18D or the 34D will display Caller ID information if your system is connected to a telephone line. (One of these modules: 206EC, 308EC, or 400EC, is required. If you have a T1 line, you can't get Caller ID.)
I hope this helps.
Sep 17, 2013 | Avaya Partner 18 Telephone 3158-05
I have a precor 935 that is showing error 5 stuck key that wont clear. any ideas
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 01, 2012 | Precor 935 Premium Series Treadmill
I am getting a reading on the screen of "er 05" i
Corrective Action
Mar 21, 2011 | Precor 9.31 Treadmill
My 05 Ultra Classic keeps displaying "tip" on the
it means your bike was tipped over. It should reset after a short while. Unfortunately I know this from experience.
Feb 23, 2011 | 2005 Harley Davidson FLHTCUI Electra Glide...
Wd860 showing error F-05. What does this mean?
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Apr 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Code P0174 05 Corolla
I don't show any po174 for an 05 corolla. But I do show a po741, if thats the code you're getting.
It means theres a problem with the torque converter
clutch system. It could be the tcc solenoid. Either way, it's related to what you just had done.
Good luck.
Feb 01, 2010 | 2005 Toyota Corolla
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
