Question about Dryers
I have a Maytag Atlantis Dryer Model MDE6400AYW - it is making a loud screeching noise which seems to be coming from the rear of the dryer. I have unplugged it and removed all the lint from every possible place but I think I need access to the drum as there may be something loose in there. How do I access the drum? Can I do it without removing the back of the cabinet?
  • 59 Answers
If you remove the screws from the lint trap shute, unscrew the 2 screws on the back side of the control panel, on the outer back, and take a flathead screwdrivew or putty knife to the front corners of the lid, you can pop the tabs and lift the top to remove the front of the dryer, to access the drum and motor.
Posted on Apr 10, 2011
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Electric dryer makes a screeching noise while
could be your pulley or rollers or the motor itself you have to take the entire unit apart and visually inspect where the noise is coming from could be rear bearing if the model is old enough if you are not mechanical i suggest you call a tecnician hope this helps
Jul 15, 2010 | Maytag Dryers
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer won't run
Maytag Atlantis Series MDE6400AYW --
Current is good, brand new power cord, drum light comes on --
When I turn the timer, I can hear it clicking, but nothing else works.
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer screeching when on
likely has a slipping belt , it will smoke before too long,
unless something got between the drum and door and is scratching .
Mar 22, 2008 | Dryers
Dryers Logo
174 people viewed this question
Top Dryers Experts
