Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
My propane tank is full, but none of my 3 burners come on, 1 does very slightly but then goes out, help! thanks
    Brigadier General:
  • 4,736 Answers
Turn the propane tank valve to OFF. Disconnect the hose from the tank and wait 5 minutes. Then, reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank first and turn the burner knob to high. Does the flame height look as it should? I f it does, light the remaining burners the same way, one at a time. Do all the burners burn as they should? If so, you solved the problem. If not, you need to replace the grill hose/regulator assembly. You can get one from any home center or hardware store that sells gas grills and accessories. Just take your old one with you for comparison purposes.
Hope this helps and Happy Grilling!
Posted on Apr 10, 2011
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Grill won't start
if your sure the propane tank is full, and the valve is open, (counter clockwise, and the control knob is on? you should not only smell it after 20 seconds, but if you put your ear near the grill you should hear a sound like air leaking.If you hear nothing and smell nothing, good chance there is a blockage in the line, or the burner holes are filled with drippings. First off, get a wire brush and scrub the burners where you see the small holes that the flame normally comes out of, then try the grill again, if still nothing (and your 100% sure the tank is full, the tank is on, and the control knob is on high) you may need to start taking apart the grill, looking for a blockage, many times its below the control knob where you will see an adjustable screen, spider webs and such will get in there and block the flow. Remember to not do any of that with the tank on the grill, remove the tank first.;
Jul 27, 2012 | Weber Q 320 Propane Grill
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
I HAVE A FULL TANK OF PROPANE, IS NOT GOING THRU THE LINES. WHAT SHALL I DO?
The best thing you can do it the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Sep 22, 2011 | Brinkmann 810-8410-S Stainless Steel...
Low flame - even at full power. Help! Propane tank is full.
there is a high flow check valve in the regulator designed to prevent large amounts of propane from escaping. sometimes this gets activated by turning it on with the burner valves open. 1. turn tank valve off 2. open burners .3. close burners after 10 secs. 4open tank valve slowly.
Sep 17, 2011 | Grilling
My Ducane grill is not burning at full capacity.
check the orifices they can get clog!
Dec 06, 2009 | Ducane Grilling
Low flame
Either ;
1 your valve is not opening on your tank,
2 your regulator is bad on your tank, or
3 your out of gas.
Unless your second burner is going fine then you have :
4 a bad burner valve control not opening or
5 Some cobwebs inside the burner blocking the gas flow.
If this helps you please rate me with as high a mark as you can. Thanks for using Fix ya and Good Luck
Mar 26, 2009 | Ducane 30400040 Stainless Steel Grill
Burner goes out
Yes it could well be a pressure problem .
Apr 15, 2017 | Broilmaster Premium P3 Grill
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
243 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
