Question about Mitsubishi VS-60607 TV
My convergence color is not converting - Mitsubishi VS-60607 TV
  • Mitsubishi Master
  • 1,216 Answers
You will need to replace ICs STK 393-110. These are located on the signal module. This is the board that has all the RCA and RF connections. Then you will inspect and replace any low ohm (under 10 ohms) at 2 watts. You are looking for, may be two or three resistors that are bad. And when you are through with replacing these components, please resolder any and all bad solder grounds (broken solder connections) on the convergence board. It will take some effort, but I think you can do this. If you would like a more detailed view with photos see the website,wwwTvRepairKits.com. Good luck and show all hands of support. Thanks for asking me!
Posted on Apr 10, 2011
Convergence color is not converting
Replace convergence IC (location 8c01) which is a STK-393-110. You will need to order an after market market convergence IC (STK 393-110) I have had good luck with this IC. Next, check and replace all the 3.9 ohm 2 watt resistors, that are bad. You can check them with an ohm meter or visually inspect for burns or peels. Resolder the Convergence board, as by now there are many bad grounds (broken solder connections). Be sure to resolder the jumper jacks that connect the board to the next board too.(Under this board are solder traces that adhere to the jumper connections that will snap to the next board.) These would include jumper jacks PM, VU, and PF. Good luck and thanks for asking, show all hands of support!
Apr 10, 2011 | Mitsubishi WS-55807 TV
Changed IC converters, 1-2 message (no problems?)
Are you talking about your convergence ICs ? and Did you use STK392-570s?
Dec 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Can not convert the colors in my Rear Projection Television Converge red blue and green
Thats caused by the convergence ICs . You can get the repair kit for your model at the following link . The kit contains both ICs and the 12 feed resistors plus step by step instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
May 28, 2009 | Televison & Video
Conversion box is worn out what should i do?
You will need to replace the convergence ICs. What is the model number of your set and I will assist you.
Apr 26, 2009 | Philips Televison & Video
Red and Yellow blurred picture
I had the same problem this week. I tried the convergence thing but it was impossible to fix. I still needed the repairman. He changed two convergence units ($325, parts and labor). Then the tv was still doing the same thing. We had to adjust the convergence and now everything is perfect. You will need your converter
Mar 01, 2009 | Akai PTH5498 54" Rear Projection...
The color converter
Seems to me you maybe experiencing a convergence issue rather than the color converter. (Don't know what he means by that for that I am an a tv repair technician).
If it is what I beleive it to be, you need and experience tech to do the work for you. It usually contains replacing two convergence IC packs along with some resistors and sometimes power supply parts. All wich requires good soldering work.
Jan 09, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Sharp TV model 27H-S60 convergence
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
May 22, 2008 | Sharp 27H-S60 TV
Samsung BP95-00142E Convergence Board changed still having a problem with the blue color
Actually the TOP Left blue corner cannot be allinged properly thru manual blue convertion.  Red is aligned correctly.
Oct 30, 2007 | Samsung PCN5425R 54" Rear Projection...
Hdtv function only out of focus
Most have HDTV Converter Box with component, Going to RGB Cmp1 or 2 a composite output cable box will not work.
Oct 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Main color
The Matrix?? Color converters. Ok Lets assume you mean the screen controls that adjust each color of the Picture tubes?? No you can not. Oh maybe your taking about the convergence? Its only necassary to adjust the lines on the GRID or CROSSHATCH if they are drifting and out of alighnment. You certainly can, if your tweeking the controls all the time, wear them out but that would take alot of tweeking. If your set needs tweeking all the time then there is a problem in the convergence and should be addressed asap or the problem will get worse. ou should never go into a set as theres high voltage even when the set is unplugged for a while and will hurt you bad. Always seek a pro in case you need any internal alighments or tweeking. Good Luck
Jun 09, 2006 | Hitachi 60EX01B 60" Rear Projection...
Mitsubishi VS-60607 TV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
