Question about MPC Computers ClientPro 365 PC Desktop
Problem is frund audio pin - MPC Computers ClientPro 365 PC Desktop
  • 81 Answers
Please connect front audio cable with motherboard in the a audio port of motherboard.If we work with sound card then connect front audio cable with sound card.
Posted on Apr 25, 2011
  • Nazar M Apr 25, 2011
My fb chat option is disable , thats way i am not chat with my frund.
Down at the bottom right of the screen, under the chat, there is a little icon that is round. Click on it. Click on the option, Available to chat. This should solve your problem. var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Aug 10, 2011 | Computers & Internet
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
You'll need to download and install Adobe reader to view the manual;
http://www.adobe.com/products/reader/
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40422
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Cheers'
Mike
Mar 08, 2010 | Computers & Internet
Heil microphone gm series wiring diagram to suit kenwood ts 450
This is the pinning of the GM-series.
pin 1- Ground / shield
pin 2 - Mic (audio)
pin3/4 - PTT
On the 450 the next;
pin 1 - Mic (Audio)
pin 2 - PTT
pin 7- Ground (Audio)
pin 8- Ground (PTT)
Good luck,
Gerard
Jan 21, 2010 | Heil Sound PR-40 Professional Microphone
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Which is the appropriate pin to connect audio out and mic pin
If your CPU is vertical then you have plug your audio pin and mic pin at rear part.
If your CPU is horizontal then try to do this at front part.
And you can also find it as , howmany pins in your cable.
Nov 14, 2009 | MSI RS482M4-ILD Motherboard
Ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Feb 06, 2009 | IBM Computers & Internet
MPC Computers ClientPro 365 PC Desktop Logo
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Bee Santiago
rey francis basa
rey francis basa
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
