Question about Garden
The PB912M10 motor/timer unit in my Malibu outdoor lighting system has failed. Motor is running and I can see gears turning, but will not trip the off/on switch. Can I purchase this as a direct replacement?
jsrock516
  • 5911 Answers
SOURCE: Whirlpool LSR7133KQ0 no pumpout, rinse, or spin.
NO...the problem you are describing are the typical symptoms of a lid switch malfunction. The lid switch shuts the washer off when you open the lid while the drum is spinning. This is a safety feature to prevent injury from moving parts if you decide to add a garment or stick your hands in the tub for some reason while it is in operation. On some model Whirpool's the washer WILL work initially for the wash cycle, then stop when it gets to the rinse cycle. I would recommend you check your lid switch to make it is not loose or broken. Your washer is also equipped with a lid strike (a small plastic piece on the lid that activates the switch) make sure it is not broken off or missing. This will give the same symptoms of a broken lid switch.
If you require a replacement switch, they can be ordered on line at searspartsdirect.com, or you can go to your nearest appliance parts retailer. The part number for the switch is 3949247. The lid strike (if required) is part number 358684. If you need instructions on how to replace the lid switch, you can use this link if you like:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I don't know how savvy you are, so I thought I would add the instructions just in case. I hope you find all this information helpful. Let me know if you require additional assistance.
Posted on Sep 25, 2008
SOURCE: Outdoor fan motor is not running fast enough?
Thanks for the suggestion. I figured out the problem. The replacement fan motor I bought was general fan motor. it had 5 wires. Two of them went to the capacitor (this unit has combo capacitor, 3 leg). I followed the schematic diag on the motor and connected one leg to the C and the other leg to the FAN on capacitor. what was happening, the start winding was working against the run winding in the motor. Once I switch the wires in the capacitor, fan ran at full speed. thanks again for your reply.
Posted on Oct 15, 2008
gotgeek2
  • 565 Answers
SOURCE: I have a T103 Intermatic timer controlling the
Let's review your wiring. There's probably something miswired when you get symptoms like that. Let's work one circuit at a time.
For circuit #1, the incoming (LINE) black (hot) wire is connected to the #3 terminal. The white (neutral) is connected to the "A" terminal. The bare equipment grounding wire is connected to the "GR" terminal (the green screw on the case).
The outgoing (LOAD) black wire to the first set of lights is connected to terminal #4 and the outgoing white (neutral) wire connects to the "A" terminal. The outgoing bare wire to the lights goes to the "GR" terminal. It's best to twist the wires together with a pigtail, wirenut them and connect the pigtail to the "GR" terminal.
Now for separate circuit #2. The incoming (LINE) black (hot) connects to terminal #1. The incoming white (neutral) connects to terminal "A". The incoming bare wire connects to the "GR" terminal.
The outgoing (LOAD) black wire to the 2nd set of lights connects to the #2 terminal. The outgoing white (neutral) goes to the "A" terminal. It's OK to twist all the white neutral wires (incoming _and_ outgoing for _both_ circuits) together with a pigtail that goes to the "A" terminal. Use a red wirenut.
As long as you don't load the 15 amp breaker over 12 amps (this is considered a continuous circuit and it cannot be loaded over 80% per NEC), you don't have to have two circuits if you don't want too. Figure about 1 amp per light as long as the lights aren't over 100 watt. (100 watt lamp/120 volts = 0.83 amps (round to one amp)
Posted on Jan 03, 2010
  • 3640 Answers
SOURCE: replace blower motor resistor unit on 99 Malibu ?
the blower motor resistor is below glove box. remove panal under box. slide the pcm out of the way, resistor is beside blower motor. unplug wiring, take out screws holding it in then pull straight out to remove.
Posted on Jan 05, 2010
  • 11 Answers
SOURCE: E100 scooter wont run. Battery
It is possible the new controller is defective, however just because the voltage is showing 24v it may not be outputting the correct amount of amps so don not rule out batteries before checking the following:
To test a battery you need to 'load test' so (with help) connect the battery directly to the motor when weight is on the scooter to see if it will still pull.
Please also remember that you do have to push the e100 to 3mph before starting (many users do not know or forget this step)
Posted on Jul 05, 2011
My malibu timer seems to get stuck before turning itself on. It take 1 hour to trip the timer to come on?
1) Clock motor is worn out, or gears are dirty:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Take apart clock motor and add white grease to gears
Set override to ON, and plug timer into cheap wall timer.
Take advantage of 5-year warranty.
Mar 10, 2013 | Malibu ML300RTW - Low Voltage Power Pack...
Malibu Lighting ML300RTW Transformer Motor
Motor has gotten weak, and is overheating and soon will not work.
Some people report taking apart motor and cleaning gears.
Others report that they didn't record how the gears came off, and can not reassemble.
PB912M10 Clock module is not sold separately.
Switch power pack to override so lights are ON, and plug transformer into cheap wall timer.
Copy following link for tips to get power pack to last longer, troubleshoot, and warranty, etc.
Nov 04, 2012 | Intermatic Malibu 300W Power Pack...
I have to spin the timer by hand to turn the lights on and off.I have the Intermatic ML900TW transformer.It seems to me I just need to replace the timer but they have been discontinued by Malibu Lights and...
PB912 timer module is not available separately.
Following link shows available PB series model numbers:
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
If clock motor no longer operates, you can set power pack to override and then plug power pack into cheap in-wall timer.
Some people report being able to disassemble clock motor and clean gears and reassemble with a bit of white grease on gears. Other people report they took it apart and forgot to mark the tiny gears and couldn't reassemble the parts. My experience with clock motors and motors in general is once they slow down and overheat, they never work correctly again and are sorely underpowered afterwards. It would be easier to buy a cheap plug-in timer.
Jul 02, 2011 | Intermatic Malibu 900-Watt Power Pack with...
I have a ML44T automatic timer for my outdoor lights which has been working perfectly until now. When the time turns until it gets to the point where it has to trip the switch to turn the lights on it...
The clock motor has gone bad.
There are no replacement clock motors.
To work around, buy cheap plug-in timer, set power pack to override and plug power pack into cheap timer.
Power packs have 5 year limited warranty.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Mar 08, 2011 | Intermatic ML44T TRANSFRMR WITH TIMER 44...
Had to replace a fixture today. when I replugged the lights the lights turn on manually but the clock on the timer does not advance I have 56 watts of light Is the timer broken?
If clock motor does not rotate, then some people report taking it apart and cleaning gears.
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
Nov 29, 2010 | Intermatic Malibu 121W Power Pack...
Timer will not tirun on the lights, it stops when it gets to the time to turn on.
Malibu home page
Malibu manuals
Try the manual override >>> un-plug power pack and try loosening manual override with WD-40
It sounds like the clock motor is unable to push the manual override
Don't continue to run power pack or the clock motor will burn up or break a plastic gear
If manual override will not work, or clock will not trip on lights, you need a new power pack
Power pack size chart and wire length
Be sure to buy same wattage power pack as you have
The 300 Watt unit is made for 15 - 20watt bulbs (15 x 20 = 300)
If you buy 600 Watt power pack and hook it up to 10 - 20 watt bulbs, it will burn out the bulbs
Manual also says to replace burned out bulbs ASAP or other bulbs will burn out.
Oct 09, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Gears stripped. can I buy the timer unit
Sep 30, 2009 | Intermatic Malibu 121W Power Pack...
I have a malibu ML121RT timer that just stopped working. Outlet works, new lightbulbs, didn't nick power cords to outdoor lights. What could be the problem?
If transformer no longer works, then it is not repairable.
Jun 16, 2009 | Intermatic Malibu 121W Power Pack...
Where can I get a timer motor for an Malibu low voltage transform
Apr 21, 2009 | Intermatic Malibu 121W Power Pack...
What timer motor fits in Intermatic ML121RT Power Pack ?
Apr 11, 2009 | Intermatic Malibu 121W Power Pack...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
