Question about Refrigerators
WE HAVE A GE model GSS25JEPA SIDE BY SIDE REFRIGERATOR AND THE WATER IN THE DOOR DOES NOT WORK. THIS HAPPENED BEFORE AND WE HAD A REPAIRMAN OUT TO FIX IT. HE DID, BUT IT STOPPED WORKING SHORTLY THEREAFTER AND DO NOT UNDERSTAND IT. IS THERE A PROCEDURE I AM NOT FOLLOWING TO GET THIS TO WORK? I AM LEERY ABOUT ANOTHER EXPENSIVE SERVICE CALL THAT WILL RESULT IN FAILUE AGAIN. WHAT CAN i DO
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
pilungu
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
aasc
  • 1606 Answers
SOURCE: Our water dispenser on our GE side by side
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in door is frozen , GE has a heater kit , pt # WR49X10173 , for this particular problem . It comes , with installation instructions .
Posted on Jan 01, 2010
Testimonial: "We will try this! Thank you!"
mrfixit3667
  • 262 Answers
SOURCE: Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Posted on Jan 07, 2010
woodchuck789
  • 4070 Answers
SOURCE: ge profile refrigerator door stop isn't working
Did it ever work or for some reason you never noticed it before? I've had to swap the door stops to get the door to stop. They can usually be swapped around according to what's needed in different situations.
Posted on Jan 20, 2010
My GE side by side makes crushed ice when I want cubed.
You might want to call a repairman to correct that problem.
Dec 18, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
Our model number is the GSS25JEPA and the ice in the ice machine leaves a after taste seems like it is a chemical taste and strange smell on the ice that the machine makes. I am not sure what to do.
I would suspect the water supply to the refrigerator. After it has sat without use over night at least, turn the water off and open the fill line at the refrigerator and place it in a clean container. Turn the water on gently for a very short time then check what you have in the container. More then likely it will contain what you are saying is in the ice. If not then you need to thoroughly clean the freezer and ice maker, my preference is to use a mild soap and bleach solution. The bleach would kill any mold that may be present.
Good Luck,
Gilshultz
Dec 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrigerator model GSH25KGRB # HG256690 NO WATER OUT DOOR.
I use a hair dryer to defraust the door. This refrigerator is very sensitive to tempature change. When it gets cold out and you have the tempature on high, the water freezes in the door.
I cover the opening of the freezor with a piece of plastic cut to fit. I tape it in place with blue tape. I tape the door switch down so the you can test the water to see when it is running again. I use the hair dryer With the door open I concentrate the heat on the right side center section. It usually takes about thirty minutes. I put a glass in the water compartment and I try the water every few minutes until it flows. Finally, I run the water for two or three minutes after it starts to flow to make sure all of the frozen water is clear. Thom
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Clicking noise
your repairman is correct . common problem with this GE
Mar 05, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge, water dispenser is not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Mar 14, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
