Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Colors will not converge on my RCA SRS Focus, model D52130. When I make an attempt to automatically converge, it says to reduce the light in the room. We even covered up the screen with a blanket at nighttime with no lights on and the screen keeps telling us that it's too bright to converge. Please help! How can I fix this?
  • RCA Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs thColors will not converge on - 578ba6c.jpgnged.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2011
Out of convergence - getting error that sensor is not getting any signal during auto-converge - is there a way to manually converge - or replace anything??
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
Picture of a set that needs the fluid changed.
69189a5.pngSOLUTION
Jan 15, 2011 | RCA D52130 52" Rear Projection Television
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
It is like looking at 3d in all three colors. i
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
May 30, 2010 | RCA D52W19 52" Rear Projection Television
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
  • Screen looks 3D
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Picture dim with red and blue cast already cleaned lens
Was the mirror dirty or damaged? If it wasn't I would try to use auto convergence. It should fix your problems. If it still seems a little dim adjust the colors in the menu.
Mar 07, 2010 | RCA D52130 52" Rear Projection Television
52" Rca model#D52W20 Perimeter is blurred, almost bowed. Not very clear.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca big screen model p52939
If you cannot get a good convergence then the convergence modules need replacing.
Jun 20, 2017 | RCA P52939 52" Rear Projection Television
Can not foucus the colors
What model set do you have ? Its probaly convergence ICs faulty.
Jan 07, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
181 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
