Question about Admiral AAV7000A
My oven display panel is black no clock nothing. the oven light works and the gas range works. could it be a fuse its 2and half years old
    Brigadier General:
  • 6,277 Answers
Sorry but you have posted on the washing machine forum so you might not get a reply other than this one ;-0(
Try re-posting onto the oven one and good luck!
You could score this one accordingly though!
Thanks,
John C
Posted on Apr 10, 2011
The power control for the oven just blew, there is no lights or power to the panel CPDS3085KF The stove is just over a year old Thanks for your help! Sharon
first check the breaker, then make sure your getting power to the oven if you are getting power ( 240 watts ) and still no display on the panel then you will need to get a new ERC board which is the control board/clock.
Apr 09, 2011 | Frigidaire FPGS3085KF Stainless Steel Gas...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Thermador prd486edg oven/heating flashing 1/2and neither oven heats. help!
only code that is close ( e12) ( E12) look at display and make sure .. mm if the code is E12 then " CT oven:latch switch problem ) this may help Note E . 1 turn the clock selector knob to off 2 tweak the oven control by turning the clock selector slightly to the left ( counter clockwise ) this may stop the flashig message / beeping and clear the display window. " try it and pray mm .
Dec 09, 2009 | Thermador PG304BS Gas Kitchen Range
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Mar 04, 2009 | Whirlpool GY396 Electric Kitchen Range
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Admiral AAV7000A Logo
43 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
