Question about Dell OptiPlex GX270 PC Desktop
CD Drives not working
I have a Dell Optiplex GX270 and have recently changed the Motherboard. I did have one CD-RAM drive not working properly but now both drives will not read or write. They both show up in the Control Panel Hardware Devices and are enabled. I can see them both in Windows Explorer but when I insert a CD or DVD they both whirl and then shut down. I have tried changing one to a older but working CD Drive but the same problem exists. One is configured Master and one Slave.
    Scholar:
  • 65 Answers
Their may be a problem with the motherboard itself. or try updating the drivers ind the device manager.
Posted on Aug 07, 2008
Dell GX270 has D amber light
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 23, 2014 | Dell OptiPlex GX270 PC Desktop
Tip
How to Find the Dell Part Number for a GX270 Replacement MotherboardIf the...
How to Find the Dell Part Number for a GX270 Replacement MotherboardIf the motherboard of your Dell OptiPlex GX270 desktop computer starts to malfunction, find the replacement part number online by obtaining the Dell service tag located on the back of your equipment. The service tag is made up of five to seven alphanumeric digits and is specific to your desktop computer.<br /><br /> <span>Instructions</span><br /> <ol> <li>Unplug your GX270 desktop computer and turn the device around to the back.</li> <li>Locate a white bar-coded label affixed to the side of your desktop computer. The service tag for your computer is imprinted on this label.</li> <li>Visit the Dell upgrade and replacement parts web page and enter the service tag for your computer into the "Service Tag Search" field. Click "Search."</li> <li>Navigate to the "Compatible Parts" Section and click the category "System Drives." Type "Motherboard" into the search field, then click the "Search" icon.</li> <li>Click the link for the GX270 motherboard. Scroll to the section "Component Part Number" to locate the GX270 motherboard part number.</li></ol><br /> <span>Other Tips</span> <ul> <li>Also find the part number for your GX270 motherboard within the "Replacement Parts" section of your owners manual.</li></ul><br /> <span><span>References</span></span> <ul> <li><a href="http://www.dell.com/downloads/us/products/optix/gx270_spec.pdf">Dell: Dell OptiPlex GX270 Overview</a></li> <li><a href="http://support.dell.com/support/DPP/Index.aspx?c=us&l=en&s=gen">Dell: Product Support for OptiPlex GX270</a></li> <li><a href="http://support.dell.com/support/topics/global.aspx/support/en/identifyyoursystem?c=us&cs=19&l=en&s=dhs&%7Elt=popup&%7Emode=popup">Dell: Find Your Service Tag</a><br /></li></ul><br /> <span><span>Resources</span></span> <ul> <li><a href="http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&s=dhs&%7Eck=anav&category_id=7566&ST=dell%20replacement%20parts&dgc=ST&cid=17745&lid=774124&acd=sqx784iXu,5531454746,901pdb6671">Dell: Replacement Parts Web Page</a></li></ul>*please leave a ratings if this information is helpful and beneficial to you.<br /><br /><br />Regards<br />MultilinkEnt.
on Jul 12, 2011 | Computers & Internet
Beeping
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
the grrr is the sound its not getting enough power
test your PSU power supply unit or replace it if the fan is not working the PSU is faulty
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 16, 2010 | Dell OptiPlex GX270 PC Desktop
Dell optiplex 270 startup
sounds like power supply failure. You can try removing all of the ram and pressing the power button again. If nothing happens, its either a bad power supply or a bad motherboard.
May 22, 2010 | Dell OptiPlex GX270 PC Desktop
I am having a optiplex gx270 but i am facing a problem to install harddisk even i changed jumpersettings it is not working and even cable also changed but i donno watz the problem
First think I would try would be to set bios back to default
Seconed, set all drives to auto in bios
Third remove the cd cable from the motherboard
fourth try drive on cable select
fifth try drive on master
sixth is drive fdisked?
Seventh try drive on another computer.
Jan 15, 2010 | Dell OptiPlex GX260 PC Desktop
Why does my dell oplex gx270 dont show any thing on the screen
this is because there is fault in the ram . replace the ram and the problem will be fixed . basically in dell optiplex gx270 when ram do not work the system becomes blank . try to plug out the ram an plug in if system didn't work this time then you have to change the ram
Dec 18, 2009 | Dell OptiPlex GX270 PC Desktop
CDDVD RW drive won't open /won't burn CD
Drive is more than likely fried. It's not uncommon to have DVD/CDRW drives or any burning drive go bad especially if you use it frequently. Check www.newegg.com for a replacement they shouldn't be more than 30 dollars for a decent model now.
Jan 09, 2008 | Dell OptiPlex GX270 PC Desktop
I need Drivers!
try the
www.driverguide.com
scan your computer for hardware update drivers there you will see the name of the hardware and then download the driver.
Jan 03, 2008 | Dell Latitude CP System Board (...
Dell OptiPlex GX270 PC Desktop Logo
127 people viewed this question
Alun Cox
