How i can download internal multi DVD Rewriter 22x in windows 7
    Scholar:
  • 113 Answers
With the Computer off install the dvd rewriter and after installing it turn the pc back on and after it boots up and you get back to the desktop The Found New Hardware Wizard should pop up and load the appropriate drivers and then restart the pc and that should get you going.
Posted on Apr 10, 2011
    Sergeant:
  • 189 Answers
Are you talking about the drivers for that optical drive? Just go to the manufacturer's website and find your model. They should have all the downloads necessary for you.
LG GH22NS70 Super multi DVD Rewriter just used
Power cable attached, interface cable attached, (Dta cable), and the small audio cable attached, plus computer on, and Windows loaded.
Windows XP:
1) Click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) When Device Manager loads, left-click on the + sign to the left of - DVD/CD-ROM drives
7) Right-click on the name of the optical drive.
8) Left-click on Uninstall
A Microsoft 'squawk box' will come up,
"Warning you are about to uninstall this device"
It's okay. Click on OK.
Close all windows, go back to your desktop screen.
Turn the computer off normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute. Turn the computer back on.
You should get a pop-up out of the system tray, "Found new hardware", and perhaps another one will follow, "Found XXXX DVD drive"
No? Doesn't work?
Try using another 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The IDE harddrive shown, is just an example of a device that uses a 4-pin standard Peripheral power cable. Mistakenly referred to as a 'Molex' power cable)
Make sure the interface cable (Data cable) is plugged in tightly.
Regards,
joecoolvette
Jul 17, 2011 | LG GH22NS70 Super Multi 22X SATA DVD...
Install LG 22x DVD internal Super Multi DVD Rewriter. Dell says no provision for writer, use external hard drive. LG says compatiable. May not be updating system. May not be putting jumpers on correctly.
Change the jumper to either cable or slave if not on a separate cable if it is separate you can use the master jumper. It will read secondary master. Or it will read secondary slave. Check that out make sure if on the same cable of the hard drive it needs to be a slave. Please post a comment if this assisted you. Thanks for using FixYa! John
Feb 21, 2011 | Dell Dimension 3000 PC Desktop
I have upgraded from windows Vista to windows 7 and now it will not recoginze my Internal/GH 22 super Multi DVD rewriter 22X? So I cannot play cds or dvds at all.
Do you have a drivers disk for the DVD player that has windows 7 drivers on it or is that version of windows 64 bit and the is no driver for that DVD player.
Feb 05, 2011 | Acer Computers & Internet
Just bought a new DVD burner, its a LG Super Multi DVD ReWriter 22x (Gh22LS40) I also had to buy a sata to IDE converter for my motherboard that has only IDE connectors on it. I can not get Windows 7 to...
ok here's what you need to do.....
first check your dvd burner if its is detected properly on your cmos. If it is located properly try to re install windows 7 again i've encountered this problem before and i just reinstalled windows 7 and it worked like charm.
If the dvd burner is not detected on cmos try to check the jumper settings for both hard disk and dvd burner one orf the other should not be on the same setting ex. if your disk drive is on master you should set the dvd on slave and vice versa. then redo the first step. hope this helps
Jan 11, 2010 | Gateway GT5220 PC Desktop
Need Driver for LG GH22 22x DVD Drive
Remove the new drive -- and look VERY closely on the back.
You'll find a "two-by-four" grid of gold pins, probably with a black "jumper" between a pair of pins.
Look closely at the labels above each pair of pins:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper from its current position to one of the other pins.
Reinstall the drive, and reconnect the power and data cables.
Check that the other-end of the data-cable is snugly connected to the motherboard.
Windows should now "detect new hardware", the next time you start-up.
Dec 28, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
LG GH22LS40 will not work
You will need to check few things to get it working.
1) See that you have attached your DVD cable on the proper port of your motherboard.
2) See that the required jumper is fixed in proper place of your DVD writer.
3) Power cable of your DVD writer.
All the Best
Sep 11, 2009 | LG Electronics 16x DVD and 48x CD-ROM...
I just had an internal super multi dvd rewriter GH22 by LG installed, but don't know how to use it. where can I get some instructions ? Why won't it play my music cd's?
in order to play music, it has to be pluged into directly into your sound car iva a special 4 pin conector (only one drive can be pluged in at a time). copying files is easy, just drag them into the drive folder just like copying stuf to a flash drive. but instead of pushing the eject button, right click in the folder ans select eject. this will start the copy procedure. to copy music use the rip tab in windows media player. for copying dvds you will need a third party program. i recomend VLC media player, it's available free from download.com
Aug 14, 2009 | LG GH22NP20 22x Internal DVDRW Retail Kit...
Cd driver
you do not need a driver cd for installing the driver for cd/dvd drive if you are using windows xp or any of its higher version as all the hardwares are auto detectable in these operating systems....go to device manager and scan for hardware changes
Dec 29, 2007 | LG Electronics 16x DVD and 48x CD-ROM...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
