Question about Garden
I have a MOEN, single handled tub anbd shower facet cartridge number 1200. I bought a tool to remove the cartridge. When I pulled on it the inside inside tube with the six water controllers came out leaving the outside of the cartridge in the brass cartitridge holder. How can I get the outside part of the cartrdge out? I was told the I might try heating the outside of the brass cartridge holder and the rubber seals might become soft enough to put it out, but how do I grab the outside of the cartridge? Robert Carlson plumbbob48@comcast.net
  • 8,197 Answers
You can watch the viedo below to see how to remove the outer ring of the cartridge.
http://www.youtube.com/watch?v=CC_45AG63HE
Or you can buy this tool on the link below to do it the correct way. The top part where the t handel is, Is a part thet you push in then tighten the t handel till tight. Then you just work the handel back and forth till You can pull out the outer half.
http://www.amazon.com/No-Manufacturer-Faucet-Cartridge-Puller/dp/B00065DLFU
Posted on Apr 10, 2011
Moen shower fixture has uneven water flow and drastic hot temperature
Remove the handle and adjust the temperature limit stop. This is a plastic geared piece which you can pull out and spin clockwise to they 1 o'clock position and then put back in. This prevents your handle from spinning too far to the hot side. As far as uneven water flow goes it sounds like your showerhead may be clogged. Put a 50/50 solution of vinegar and warm water into a baggie and place it onto your shower head using a rubber band to keep it in place. Your uneven flow may also be a result of a partially clogged cartridge. If that is the case, change the cartridge. Here are the instructions.MOEN CARTRIDGE REPLACEMENT There are two different types of Moen cartridge for a single handle valve. The first and most common one is the plastic 1225 cartridge that is used for all Moen single handle valves that are not posi-temp shower valves. This cartridge also comes in brass which is number 1200, but it is more expensive and doesn't last any longer or work any better than the plastic cartridge. The posi temp cartridge is a number 1222. This is the replacement cartridge for shower valves that you turn rather than pull. As you turn the valve it goes from cold to warm to eventually hot. The tools needed for this procedure are pliers, Phillips screwdriver, a small flat screwdriver or awl, a 3/4 inch copper cleaning brush, silicone or heat proof grease, a knife to pull the cap on an acrylic handle, or a 7/64 inch Allen key to remove lever handle.
If it is an acrylic handle simply pry off the cap and unscrew the screw with a Phillips screwdriver. If it is a lever handle there is a set screw which is 7/64 of an inch. Use an Allen key to remove this set screw. If it is a lever handle when the handle is removed you must use a Phillips screwdriver to remove the handle adapter.
Before removing the cartridge make sure that the water is turned off and open the valve to bleed off the pressure. Leave the valve in the open position as it will facilitate the removal of the cartridge if the spindle is in the open position. It can be turned off at the main which is usually the easiest thing to do, or you can remove the faceplate and there may be integral stops behind the faceplate. Use the integral stops if your water main is hard to reach. On the brass spindle of the cartridge there is a notch on one side. Before you remove the cartridge take note of what position this notch is in because that is the position in which the cartridge will be placed. Do not forget this step as a posi temp cartridge will not function properly if installed with the notch in the wrong place. If you install the regular cartridge with the notch in the wrong place, hot and cold will be reversed. Simply remove the handle and spin the spindle 180°.
Pull off the chrome stop tube that encloses the cartridge. There is a horseshoe-shaped retainer clip that must be removed. Use the small screwdriver or all to pry up the top of the retainer clip. A plastic square head removal tool comes with the cartridge that you have purchased. Place this on the cartridge and spend back and forth to loosen the cartridge. Then take your pliers pull the brass spindle straight back towards you. If this proves too difficult and you are unable to pull it out you will have to buy a Moen cartridge pulling tool. Be sure to buy the right tool as they are not interchangeable. The posi temp tool is much fatter than the regular tool. The tool operates the same way a hub puller. Back off the knot on the tool as well as the screw. Place over the cartridge and advance the screw all the way. Now advance the nut.
After the cartridge is removed take the 3/4 inch copper cleaning brush and insert into the cartridge housing while spinning clockwise. When removing the brush also keep spinning it clockwise. After brushing, open the water main for about three seconds to flush the line out.
When installing the cartridge make sure that your notch is aligned properly and that the cartridge is pushed in all the way and that the two tabs on the cartridge are aligned vertically. Install the retainer clip. If it doesn't go in all the way either the cartridge has not been pushed in foreign off or the two tabs are not aligned properly. You can use the plastic tool to align the tabs properly and to help push in the cartridge all the way. Reassemble faceplate and handle and you are done.
Jan 05, 2014 | Moen & Posi-Temp Single Handle Shower Or...
I have a moen single handle tub and shower faucet took out the clip and pulled but the stem will not come out what esle is holding it
You need to purchase a replacement cartridge before trying to remove a defective Moen cartridge. Always buy genuine Moen. If your valve turns on and off with a pull/push action you need part number 1225B, otherwise you need part number 1222. The 1200 cartridge will work in lieu of the 1225B but is more expensive and no longer used in Moen valves. There is a tool that comes with these cartridges which looks a bit like a white plastic cap.with notches on one end and a square head on the other.
Once the clip has been removed the only thing keeping the cartridge in the vslve is old sticky lubricant. Place the tool over the cartridge end and rotate as necessary until the notches are fully engaged and it no longer rotates. Using pliers or a wrench over the squared end, twist the tool back and forth several times. Remove the tool, and using pliers, pull the old cartridge out. Put the tool on the replacement part and insert it back into the valve. Lightly tap on the squared end to make sure the new part is completely seated, then use the squared end again to turn the cartridge as necessary to align for the clip to be reinstalled.
Nov 06, 2010 | Moen & One Handle Tub & Shower Faucet
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
On my Moen shower facet
There is a small "U" type clip that comes down in front area to hold it in, I assume that has been removed. The new cartridge should have come with a small tool (usually plastic) that you put over the cartridge, push it in, and turn the body of the cartridge, and it should start to ride up on higher brass sleeve and start to pull itself out. If you look at vertical part of cartridge, it is sitting back in on low spot of the sleeve. That tool, or a pair of strong needle nose pliers,needs to be against the sides of the vertical part of the cartridge, in such a way that when you rotate the cartridge, it rides up on higher part of sleeve, and pulls itself outward.
Apr 16, 2010 | Moen & One Handle Tub & Shower Faucet
Put a lever handle on the tub/shower fixture, now temp doesn't
hi carey. turning the cartridge upside down will not change the direction. But tell me this, once you get used to the new cartridge won't it be fine as it is?
Jun 18, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
