Question about Kenmore Cooktops
On a Kenmore range model # 665.95775890. The dual element burner works with the thermostat control goes on and off, but it won't turn off stays on. I had to turn off the breaker, ETC.
aborcass
  • 2651 Answers
SOURCE: Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Posted on Mar 16, 2008
SOURCE: can't adjust temperature on solid elements
replace the switch!
Posted on Jul 02, 2008
jtbjtb
  • 135 Answers
SOURCE: JEC9530, dual element burner(right front) does not
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Posted on Feb 26, 2009
  • 5603 Answers
SOURCE: Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Posted on Oct 27, 2009
SOURCE: Small burner on replacement Jenn-Air range cartridge doesn't heat
I have the same issue.
Posted on Feb 01, 2011
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Jenn-Air Dual Fuel Range Model JDT8895BAS
The igniter will click on all the burners simultaneously no matter which burner knob is on. This is normal.
Aug 27, 2014 | Cooktops
I have an Amana smoothtop AK2H35 the large dual burner seems to overheat. It gets so hot, that everything burns, when I turn the temp down, the burner does not turn off, though eventually, it does turn...
Hello there
I will answer this in 2 sections for testing the burners and the thermostate
Surface Burner Testing:
In order to test the surface burner on your electric range, the following steps should be taken:
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. Remove the surface burner from the stovetop. On most electric ranges this can be done by pulling the burner up and out of its plug-in receptacle. Other models have the burner directly wired to the cooktop. To remove this type of burner, undo the screw that secures the burner to the cooktop, remove the clips that secure the insulators to the burner terminals, and carefully unscrew the wires from the terminals. Take care not to bend these terminals.
  3. Visually inspect the burner - often there will be small holes or bubbles on the surface of a defective element.
  4. Now that you have removed the burner, you can test it using your VOM. Using the ohmmeter function, set the range scale to R x 1 and touch the test leads to the two burner terminals. The VOM should show continuity. Typical burner readings should be somewhere between 19 and 115 ohms, depending on the range manufacturer. If there is no continuity, the burner is defective. To test for a grounded (or shorted) burner, place one test lead on the outside surface of the burner and the other test lead on each burner terminal in turn. If there is continuity at either terminal, the burner is defective.
  5. If the burner is defective, replace with a new one by reversing the removal procedure (step 2 above). If replacing a wired-in burner, make sure that you install the wires on the correct terminals, according to the wiring diagram
Oven Thermostat Testing:
An oven thermostat is a switch that opens and closes in response to the temperature it senses. It is typically found in the control panel, where a liquid-filled temperature-sensing bulb senses and maintains the internal oven temperature by cycling heat on and off.
  2. Access the oven thermostat, which is located in different places depending on the make and model:
    1. On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.
    2. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components.
    3. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel.
    4. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you.
    5. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  3. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
    Adjusting the thermostat:
  4. Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
  5. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Dec 01, 2010 | Amana Cooktops
Range replacement switch installation ???
sounds like you have the wrong sw . do not install . ck the old # and see it this is a proper replacement . / I did look your sw and it has a blue housing and muilti break of shaft . it should replace a standard sw but not the dual element . re ck where you purchase to make sure is the right one .. mm
Dec 08, 2009 | Cooktops
I would like a circuit diagram for a Kleenmaid CH 14 Cooktop
Hi, I too have had a problem with the dual element on the Kleenmaid CH14. Likewise I was given an Invensys M82314 which as you will know is not configured in the same way. However, I assume that what they call"phase" is the active connection, the neutral is marked and are side by side like the old one, pilot is idicated and is the wire that bridges together with the other switches....you are only left with two...."load1" and "load2" whichever way around I apply those I can only get my inside burner to run. I am baffled !! My old switch operates both burners but keeps cutting in and out.
Nov 11, 2009 | Cooktops
Oct 27, 2009 | Cooktops
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Mar 15, 2008 | Cooktops
Cooktops Logo
53 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
 Fix Your Board
Fix Your Board
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
