Question about Canon PIXMA iP1200 Photo Printer
Ip2600 printer will not feed 1 paper at a time. feeds all paper that's in the printer at once.
  • 805 Answers
That your printer roller problem. please repair it by a professional technician. thanks
Posted on Apr 10, 2011
I cant get the paper to feed without jaming is ther a way to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
Canon ip2600 won't feed paper
I fixed mine!! I cut a letter size paper in half lengthwise (so it was skinny and long). Held the printer on my lap with both top and bottom trays open. I noticed the white pegs and skinny black roller inside were turning when I turned it on, so I waited til they were spinning and slid the paper between them along the right side. (Kind of a reverse feed). Had to do it between the crazy ink returns. Yes, the paper crumpled a little, and I did it a couple of times with a couple of papers. Something gave, because after that it started feeding properly again!
Oct 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Pinter iP2600 says I have a paper jam and wont feed paper. I see no paper jam but paper wont feed.
perhaps if you got a paper when you try to remove jammed paper to a piece of paper rupr remained on paper route, and have seen where, if paper was not broken when it is possible that when you pulled a paper to be skipped sensor that never returns to the starting position
Apr 12, 2011 | Canon Office Equipment & Supplies
Paper feed won't accept photo-quality paper - the paper feed action is not smooth - it will just about take 80gsm paper but not evenly and sometimes it feeds several sheets through at the same time. At the...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Please rate this solution.
Mar 06, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Ip2600 will not load blank paper
Turn it upside down and shake. A small oyster cracker may have lodged in the feed slot causing the problem. At least that's what fell out of mine and now it works....
Aug 27, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Paper won't feed through
So why did you log this in the HP product pages? Try cleaning the rollers with a contact cleaner or alcohol based cleaner
Nov 18, 2009 | HP Color LaserJet 2600n Printer
I have a Canon iP2600. For no apparent reason, it stopped feeding paper on the left side only. On the right side, the paper catches, and tries to feed, resulting in a paper jam.
Sounds like an obstruction of some sort. Have a look on the left side with a flashlight as best you can, and see if maybe a staple or paperclip got lodged in there.
Apr 27, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Canon PIXMA iP1200 Photo Printer Logo
109 people viewed this question
old marine
old marine
