Question about Crosley CDG6000 Gas Dryer
The dryer egnites but does not come on something shuts it off. could it be a sensor?
  • 413 Answers
Did you just hook this dryer up? Sounds like you have air in the gas line.
Posted on Apr 10, 2011
Dv218aew Samsung dryer shuts itselft after 30 seconds
If it starts ok but system says somethings wrong.would guess its a sensor gone bad on you
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
Gas dryer no heat
check your sensors, they are in line with the power, basically sensors are switches that are turned on, if something out of the ordinary happens like over heating the sensor like a switch shuts off, it interrupts the power to the energize parts on the dryer and it wont work till the sensor is replaced, sensors have two wires in and out, you should get voltage on each lead to ground with a meter, if not the sensor is broke
Dec 31, 2012 | Whirlpool LGB6300 Gas Dryer
Dryer not drying clothes in a 45 minute cycle on highest temp setting
Hi you have high heat sensors test them with a multi-imeter before buying any parts
Dec 06, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Have a gas dryer...brand new...is getting gas but will not get hot. Is there a shut off valve or something we need to turn on
Is the exhaust vents old? If so clean them out or replace with new. Clogged up ones will shut down the burner automaticly by the sensor built into every dryer made
Sep 11, 2010 | Amana Dryers
I have a whirlpool gas dryer model LGQ9508PW0. It is not drying. I noticed that it would egnited the firest time but not after that. I replaced the egniter thing it was worn. Now WITH NOTHING IN IT it I...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 24, 2010 | Whirlpool Dryers
The burner egnites during the enitial start up, but does not re-egnite during the dry cycle. clothes stay damp.
The problem is the dryer coils are failing. They tend to fail as they heat up. They are easy to replace and inexpensive. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Aug 07, 2010 | Kenmore Dryers
I have always set my dryer on automatic dry. I
Clean the sensors ... they are likely coated with something. Alternatively, the sensors could have become disconnected during the move. Remove the back and check this out. Use a 5/16 nut driver - not a screw driver - youwill save yourself a bunckof grief.
Oct 19, 2009 | Dryers
Dryer will not shut off or heat up
The problems are related. The timer advances when the thermostats sense that heat is being applied to the air in the dryer. With no heat, the sensors do not allow the time to advance.
You did not mention... Is your dryer gas or electric? If Electric, the most likely culprit is a burned out heating element or a faulty internal heat-sensing thermostat. Burned wires or a defective motor switch are less common factors.
If it's a gas dryer, suspect the glow sensor (could be something as simple as lint covering it), temperature control thermostats, or the heater switch on the motor.
Jun 15, 2009 | Estate TEDS740JQ Electric Dryer
Dryer runs and heats but shuts off prematurely
It could be the timer or the sensor as well. Before replacing parts, it may just need a cleaning. If you are not familiar with the product then you should call a professional. The dryer is designed to shutoff when it is overheating, which as you stated it heats up nicely, but shuts off.
Lint, the unfortunate result of drying gets on the sensors and other parts and causes them to react prematurely. If you haven't cleaned the unit, it may just need that, if not I would then say start looking at replacing parts. For safety concerns, you should have your dryer cleaned yearly.
Another thing to check is the exaust for kinks or blockage, when this happens it causes heat back into the unit and again shuts it down.
Give those a try and it may just solve your problem.
Thanks,
Paul
My Website
Jan 28, 2009 | Kenmore 63942 Dryer
Crosley CDG6000 Gas Dryer Logo
43 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
