Question about Samsung DLP HL-P5663W 56" TV
High pitched whine when the motor starts
When the TV is turned on, you can hear the motor/fans start and then a high pitched whine gets going. It was soft at first and went away for a while. It is back with a vengance and louder than ever. You cannot even hear what is on the TV.
  • 1 more comment
  • sguiscreen Aug 12, 2008
    Yes. Exact same problem. I have to crank up volume on the TV and my surround sound to blot it out. It is irritating, because it eventually goes away after an hour and a half or so.
  • dybrownstein Aug 27, 2008
    Same problem here. It used to get softer after watching a bit, and you barely knew it was there there. Now it is so loud that you can't enjoyably watch anything. The actual sound and picture are perfectly fine. My model is HLN4365WX/XAA. Some repair dude charged me $100 to tell me it was the lamp, but I'm wary of purchasing a new one because I don't know if that makes any sense.
  • reneshiloh Aug 28, 2008
    having the same problem with a loud high pitch whine thats starts about 5 minutes after tv is turned on. Have not been able to correct.
    Problem Solver:
  • 6 Answers
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Posted on Aug 30, 2008
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
My vax vacuum has started making a high-pitched whining/whisting noise
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Feb 07, 2012 | Vacuums
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
I turn the key and it makes a sound but doesnt wat to start doesnt feel liek its getting fuell
is it a high pitched whine, or a gulging noise? if it is a high pitched whine i would go more towards the starter. the gluging noise i would check fuel pump.
Sep 03, 2009 | 2003 Pontiac Sunfire
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Aug 20, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
