Question about Fisher and Paykel DG08 Electric Dryer
My Fisher Paykel Dryer runs for about 10 minutes then completely shuts down like it is over-heating
SOURCE: help with a noisy Fisher & Paykel dryer
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
Posted on Dec 22, 2007
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
hunter19_46m
  • 7482 Answers
SOURCE: there is no heat, when i pushed the reset button
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Posted on Oct 10, 2010
Dryer spins for 10 minutes then shuts off. I have to manually start it again every 10 minutes
Its getting too hot and shutting down to protect its internals.
Make sure the filters are clear of fluff and that the exit vent is not blocked by dirt.
Dec 20, 2013 | Fisher Paykel EcoSmart GWL15
How can i reset an electric dryer fisher & paykel it runs but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
The dryer runs for abiut 5-10 minuts and then shuts down. Then if you wait a little it will start again but repeats the process. What could it be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Fisher and Paykel DG08 Electric Dryer
My dryer is working and it is drying (It has heat) however, it will just stop in mid cycle. Im not sure if its overheating or if that is even an issue. But if I wait about 5 minutes and then hit start...
heatman101
Sep 06, 2010 | Fisher and Paykel DE06 Electric Dryer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel dishwasher dd601I runs complete normal cycle and finishes normally. 2-3 sec. after completion the washer motor srarts to run and the f1 fault (flood sw. activated) is dislayed. When the power...
Hi
F1 code indicates an overfill condition which may cause when dishwasher can’t pump out dirty water due to a plugged drain hose.
open dishwasher fully ,dry up as much water as possible then put a hair dryer on hot and direct into the back of the cabinet you will see a grey plastic cover on the bottom floor this is the sensor run on full for about 5 - 10 minutes making sure the heat go into that area. Also don’t overheat your hair dryer, when finished close the dishwasher shut and start your normal cycle.
Thanks for contacting fixya.com
Jan 20, 2010 | Dishwashers
Fisher & Paykel top load intermittent running
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Dec 06, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel DG08 Electric Dryer Logo
49 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
