Question about Canon PowerShot A540 Digital Camera
Even though I keep putting new AA batteries in my Cannon PowerShot A540 - from one day to the next it reads "Low Battery". It didn't used to do this. Anything I can do/have checked out?
  • 805 Answers
Please dear
listen before buying battery concern about the quality of batteries and they must be rechargeable and lethiam battery.
If you use no rechargeable batteries or after buying but didn't no charge then i will request you please charge your battery up to 6hours. thanks
Posted on Apr 10, 2011
I got this camera a few years ago for Christmas and unfortunatley it is the worst camera I've ever had as far as battery life. I can take 2 or 3 pictures and then it shows low battery. I've replaced new...
It seems there is some where inside the camera leakage.. Are you using Li-ion rechargeable batteries or AA batteries For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
Jan 08, 2011 | Canon PowerShot A540 Digital Camera
Every time I turn on my Canon A540 Powershot I get the black date/time screen. The date/time is all zero (the photo properties default to 1 Jan 1980) and I have to either enter the date/time or press...
Inside the battery compartment, right beside the AA batteries, there's a tiny little door labeled CR1220 (see this picture). Pry the door open with your fingernail, remove the little button battery located there, and take this battery down to your local drugstore to buy a replacement camera clock battery. Remember, it's a "CR1220" battery. It should cost only about $4.
Dec 29, 2010 | Canon PowerShot A540 Digital Camera
Camera keeps saying to replace batteries even though new ones that have been checked with a meter and are OK are installed.
Are they the correct type of batteries? Use only AA-size Alkaline or Canon AA-size NiMH batteries.
Dec 15, 2010 | Canon PowerShot A540 Digital Camera
When i put the new batery it will display "change the batery" and automatically power off the camera
This camera takes AA batteries. You must use good alkaline batteries or better, a set of high capacity NiMH recharegables. Zinc batteries just aren't up to the task.
New rechargeable batteries are supplied only partially charged. You need to charge them fully before use.
Oct 28, 2010 | Canon PowerShot A540 Digital Camera
Canon Powershot SX110is: problem with the batteries
Make sure you are using Lithium batteries. Alkaline batteries will go dead immediately in this camera. I've tried it.
Sep 23, 2009 | Canon PowerShot SX110 IS Digital Camera
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Oct 03, 2008 | Canon PowerShot A540 Digital Camera
CANON POWERSHOT A530 LOW BATTERY READING
Alicia,
Mentioned on my blog that the last paragraph of the advisory states:
""PowerShot A530 and A540 digital cameras affected by this phenomenon will be repaired free of charge, regardless of warranty status. Accordingly, if the opening/closing spring on the inside of the battery cover of your PowerShot A530 or A540 digital camera sticks out, please do not use the camera. Instead, please contact a Canon call center (1-800-OK-CANON) at your earliest convenience."
But also mentioned that if they don't help, a temporary fix is to insulate the spring from the battery contact plate. Merely place a small piece of tape between the portion of spring that's sticking out and the metal battery contact plate.
Sep 09, 2008 | Canon PowerShot A530 Digital Camera
Shows low battery after putting in new batteries
Your best solution is to use Sanyo Eneloop batteries because of their higher voltage over the discharge curve compared to regular NiMH batteries. See http://www.epinions.com/content_309637189252.
I have gotten a full week of use with hundred of pictures on one charge using a Canon A540 and a set of Eneloops. The only problem is they are hard to find, but you can get them on Amazon.com.
Mar 13, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
122 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
