Question about Compaq Visual Fortran Professional Edition 6.6 (QB-5UDAB-PA) for PC
Compaq visual fortran 6.6 VS visa
Hi
I have some difficulties in installing cvf on my new purchaced notebook. my operating system is vista home premuim with vista service pack 1. despite problems which i have, some of my friends successfuly instaled the software. when the installation progress reachs 96%, and error window ocuures."setup wa unable to create 'compaq visual fortran 6'. please create a folder named ' compaq visual fortran 6' in the start menu programs folder and retry the installation. if the problem persists, contact compaq computer corp'. what should I do?
I reaalu need this software for my projects.
last but not least, my friends installed service pack 1 manually on their system but my vista originally contains the service pack 1,
best regards
  • 4 more comments
  • Anonymous Nov 27, 2008
    I have the same problem, too.
  • tenha3296 Mar 10, 2009
    when I install compaq visual fortran 6.6,there is a message that unable to copy file C:Windows¥system32¥*.*(Error-1). how can I fix the problem?
    please send your suggestions to tenha3296@yahoo.co.jp
    thanks in advance for your great idea!
  • stewav Apr 01, 2009
    I have the same problem with XP
  • vkyvelidi Apr 19, 2009
    compag visual fortran under 'vista' does not work- I can not start exe program.
  • Anonymous May 05, 2009
    goes up to 96% and then i get the error message. However, i could install the compiler, imsl etc.. without the developer without a problem...still i have to compile the code using another machine and then copy it and run it in the vista...
  • sumitra2040 May 20, 2009
    after installing. when i start the program for new file, add in from tool for registration .dll . when i browse and click the dll file said server error.
Posted on Aug 31, 2008
I am trying to install fortran 6.5, but appears the message..."C:/windows/system32/*,* is ready only....but when I try to unread at this folder is not possible. I really would appreciate any help with...
If you are running windows vista or 7, try to launch installer as administrator. to do this right click on installation .exe file and select "Run as administrator".
Mar 23, 2011 | Compaq Visual Fortran Professional Edition...
I have installed compaq visual fortran 6.6 on my Laptop with the OS Win7 64bit Ultimate, but it doesnt work properly. The error message is: Microsoft (R) Developer Studio has stopped working.
I have successfully installed PGI visual fortran on my Laptop with the OS Win7 64bit Ultimate,and finally I have found how to build and execute programe on it.You can try PGI visual fortran. v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} p\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} v\:textbox {display:none;}
Aug 16, 2010 | Compaq Visual Fortran Professional Edition...
I have compaq visual fortran professional edition 6.6 for win32x86 systems (year 2001). I am trying to install it on my new windows 64 bit Dell desktop. It does not install. When I click the setup.exe, I...
Click Start
Click All Programs
Click Accessories
Click Program Compatibility Wizard
Tell Windows (64-bit) that you are trying to install a 32-bit application.
Or, upgrade to the latest version of Compaq's Fortran system.
Jan 08, 2010 | Compaq Visual Fortran Professional Edition...
How to run digital fortran 6 on windows vista
Here is what I did. Open the DVD (right click and select Open), and then open the X86 folder. Run the Setup.exe file from there and it should install and work fine. I had an error during install near the end, but it seems to have done no harm. I compiled one of my old Fortran apps and it works fine.
Dec 15, 2009 | Compaq Digital Visual Fortran Professional...
96% setup was unable to create the program folder
I had the same problem, to solve it I repeat the installation and when the message "Setup was unable to create the program folder" I went to installation directory "C:\Program Files\Microsoft Visual Studio" and I made a copy of the whole directory to another location in my hard drive. Then I back to installation screen and I accepted the message box. As it was expected original installation folder disappeared. I restored installation folder from the copy I had made previously. At last I created a short cut to "C:\Program Files\Microsoft Visual Studio\Common\MSDEV98\BIN\DFDEV.EXE" and started Visual Fortran from this shell without any problem. I hope this tip could be useful, regards. tbeltran
nd search for the
Sep 21, 2009 | Compaq Visual Fortran Professional Edition...
Compatibility issues between Compaq Fortran and Vista
hi,
i ill ask u to simply use a xp os, so that u wil not have such a problem occurring again. or partition you hard drive so as to install both xp and vista os.
Sep 20, 2009 | Compaq Visual Fortran Professional Edition...
Reinstallation problem
Same error here. Compaq Visual Fortran 6.5/6.6.
I think is a problem related to Windows XP SP3.
- Solution:
Re-install Windows XP SP3 (integrated).
Right after installation (no reboot) run the CVF installer. It will work.
Then do normall installation stuff.
If you have Windows XP SP2 you won't have any problem.
Hope it helps.
Couldn't find ANY solution with SP3 installed before CVF installation.
Mar 21, 2009 | Compaq Visual Fortran Professional Edition...
Problem in installing compaq visual fortran
This can happen due to corrupt installation disc. Please ask for a exchange with your vendor. Incase of a pirated disc, I would suggest , Please refrain from using pirated disc as it will damage your PC.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 22, 2009 | Compaq Visual Fortran Professional Edition...
Problem with Compaq Fortran & Vista
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
Aug 06, 2008 | Compaq Visual Fortran Professional Edition...
Compiling and linking in vista
Vista's not my favorite yet, either.
There could be a million reasons why it won't run, many of which you won't be able to do anything about.
That said, perhaps turning off the UAC security, defining another user as an administrator, and trying to run Fortran might help. At least you won't be running into the whole "run as administrator" nightmare.
But, here's another thought...
If you're machine is powerful enough, maybe you could use Virtual PC or VMWare to build an XP machine where it will run.
(I cut my programming teeth on Fortran, a looong time ago!)
Jun 05, 2008 | Compaq Visual Fortran Professional Edition...
Compaq Visual Fortran Professional Edition 6.6 (QB-5UDAB-PA) for PC Logo
3,445 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
