Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheemglas fury model # 41V50 the approx. 5 gal pressure tank above the water heater is corroded and leaking. how difficult to replace and what is the name of the tank
I have a 50 gl rheem the pilot it doesn't stay lite.
Posted on Jul 21, 2011
1) If tank is connected with single pipe to cold water line, then it could be expansion tank.
Add a comment with photo so I can see.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Take photo to plumbing supply store.
Expansion tanks unscrew from pipe. Simply install it and it has internal pressure bladder.
Has to install on cold water line.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 11, 2011
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
Which one is compatable water heater to Rheemglas fury Model#41V50?
You have 6-year 50 gallon gas water heater:
42V50 would be the newer model number. They make tall and short models.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
All brands of water heater are good.
So any 50 gallon gas water heater from local box store or hardware is good product.
Tanks with longer warranty last longer. So 9-year and 12-year water heater will last longer, unless you have very hard water or odor in water and need to change frequently.
I recommend avoiding water heaters with electronic controls since they are not protected from power surge and can cost more to repair.
Additional resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
Aug 31, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I need anode rod for my rheemglas fury model # 81V52DT. do you know what the part # is or maybe the dementions. There seems to be several diffrent ones out there. Thanks
Anode rods are generic and available from local plumbing supply store or internet.
Just cut it off so it drops into the tank without touching the bottom or sediment on the bottom.
If there is not enough room above the tank to install new rod, then buy anode rod with sausage links.
http://waterheatertimer.org/Replace-anode-rod.html
Open following link for Rheem parts: page 7 shows anode rods
http://waterheatertimer.org/pdf/Rheem-parts-list.pdf
Jul 02, 2011 | Rheem 81VP6S/430126 Water Heater
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Rusted water heater must be replaced.
For money-saving water heater information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Rheemglas Fury Model #81V52S C, MFG date 05/2003, 50 gal Does not heat properly--not long enough. I Cannot find a gauge, or know how to adjust tempeture--hope that is only problem--please...
One of the elements may be bad. With the power off check each one with an ohm meter. Should show continuity.
The tube the cold water come in through goes to the bottom of the tank. If it has come loose and the cold water stays on the top you wouldn't have much hot water.
Jan 01, 2011 | Rheem Water Heaters
How do I turn up the temp on my Rheemglas fury 82V80-2?
You have 2 thermostats inside of those covers, little things with a dial on them, turn them with a small screwdriver, Don't go too hot or you will be scalding everybody. Hope this helps.
Oct 05, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water discoloration. Rhreem serial rh0909ff00279 date 9/2003 model 8v520c 50 gal electric rheemglas fury. prolem occures when we use hot water. tried fixing...backwashed, drained water out completely...
Brown discoloration is evidence of a rusting or corroded steel pipe somewhere in you plumbing system. Trace the water lines back from the faucet and replace all the steel pipe.
White discoloration is minerals that separate out when the water is heated.
You can change the Anode Rod and it should help. It is not an instant fix, the rod will take a week or two to do its job.
If your water heater is still under warranty, call Rheem, they may replace the water heater free.
Sep 07, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
666 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
