Question about Electronics - Others
I am getting an Error 09 on my Beta SP BVW 70 deck. The tape is stuck and will not eject.
5 Suggested Answers
SOURCE: tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Posted on Mar 27, 2008
SOURCE: Betacam Sp Error Code
It sounds like you may have blown your threading belt. Pull the lid off and have a look at the small threading motor at the back left side when viewing from the front. there is a geay assembly associated with it that drives the threading ring. If that belt is off or loose you will get the error 09 message. Good luck
Posted on Jan 07, 2009
SOURCE: Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Posted on May 12, 2009
  • 221 Answers
SOURCE: Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
Posted on May 21, 2009
How to eject an HDCAM tape stuck in as BVW75 Beta deck.
I don't know what this error code means but I have managed to remove tapes which stuck in a VCR and cannot be ejected. Whether you do this is purely up to you, but it's usually possible to remove the casing (carefully!) so that you can get to the tape-handling section. Then it's a matter of gentle probing & trial and error to get the machine to release its hold on the tape. Look for a series of mechanically linked parts which are driven by motor but activated by a microswitch tripped by action of inserting the tape. Just don't strain the linkages and if you remove anything make a note of where it came from.
Apr 28, 2015 | Televison & Video
Sony bvw 75 beta sp deck error 90
not worth it as it indicates mechanism problem related to power circuit in the unit--not to mention no parts are available for this unit.
Apr 02, 2012 | Televison & Video
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
Jul 14, 2009 | Sony Betacam SP Small Videocassette 30...
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
Feb 15, 2009 | Fuji M321SP Betacam Tape
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Nov 26, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
Electronics - Others Logo
148 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
