Question about Insignia IS-LCDTV32 32 in. Television
Insgnia LCD NSLCD26A
Some how the power on led appears but there is no picture - as if the TV was off - and is cold to the touch...don't get it?
  • 3 more comments
  • beaglemom Oct 11, 2008
    the tv has the green dot at the bottom which tells me the power is on. We can not turn on at either the remote or from the power button at the tiv
  • debbierivers Oct 24, 2008
    My green light also comes on as if the tv is on but there is only a black screen and no sound.
  • mc1057 Mar 21, 2009
    Exact same problem, has anyone come up with a fix???
  • andrewh715 Apr 16, 2009
    Green light on, but no response - just empty blankness
  • soccercris May 05, 2009
    have a Insignia NS-LCD26A. It is a little over a year old. Last night while watching it stopped working. The green power light comes on the screen flashes for just a second ...
After turning on my television it black screens. I can just barely make out the snow screen and the menu but I can't see it enough to adjust the settings. Can I reset my television back to factory specs?
Posted on Sep 25, 2008
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
Apr 25, 2017 | Samsung Televison & Video
Why is my replacement LED Power Supply Board not functioning properly?
Power supply board is not the culprit - check out your inverter board which is responsible for the back lighting.
Feb 03, 2016 | Samsung Televison & Video
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Insignia IS-LCDTV32 32 in. Television Logo
703 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
