Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore range model# 790.71312700 oven wont light.No ignition or gas.Cooktop works fine. Can I run a diagnostic?
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Posted on Dec 21, 2007
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
57 varieties
  • 1653 Answers
SOURCE: I have kenmore elite gas range 790 series getting
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Nov 12, 2009
SOURCE: Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
Posted on Dec 24, 2009
Oven stops cooking, control panel says it's still on
Sounds like the igniter is going or has gone. In modern stoves there is no pilot light. The gas is ignited via a high temperature igniter. Over the years I've had a couple of them go out. The symptoms are identical to what you're seeing. Pull out all of the shelves and to bottom tray (covering the burners). You'll probably need a screw driver to get the tray out. You will see a curious looking device with wires running into it. That's the igniter. Do a Google search and identify the part, order it and replace it.
Jun 18, 2012 | Kenmore Kitchen Ranges
Maytag mgs5870adb range-gas runs, igniter does not click on any of the 4 burners. all the rest of the oven works
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Ovens
I have a kenmore gas range the oven seems to light the oven burner ever 10 sec and wont stay on model # 362.75497000
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 26, 2011 | Kenmore 71052 Gas Kitchen Range
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Broiler works but oven wont.
There is a valve on the rear to contorl the flow of gas to the oven that can be turned off or can go bad. Check it to make sure it hasn't gotten switched off and if its still not working (with swith flipped in the opposite direction) you probably have a bad valve
May 07, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Apr 10, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
20 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
