Question about Kitchen Ranges
Ignitors dot spark - Kitchen Ranges
  • Kitchen Ranges Master
  • 6,993 Answers
Below are some troubleshooting tips that can help to solve the problem;
Broken Electric Ignitor
Most modern gas stoves use either a glow or hot surface ignition system or a spark ignition system, both of which use electricity to start the flames of the oven or range top burners. The experts at DavesRepair.com say that if your ignitor does not glow or create sparks at all, or it does so only after a wait of three minutes or longer, it is likely malfunctioning or broken. Problems can occur with cracking in the ignition unit from years of use or damaged wiring that prevents the ignitor from receiving power. Replacing the electric ignitor should fix this problem.
Malfunctioning Gas Valves
Electric ignition systems in gas stoves use special valves that open as the ignitor heats up, according to DavesRepair.com. If the ignitor sparks or glows properly but the burners fail to turn on, the ignitor may not be getting enough electrical current to open the gas valve sufficiently to turn them on. Replacing the electric ignitor may fix the problem, or a new valve system may be required.
Clogged Pilot Tube
Older stoves use a constantly lit pilot light to ignite the burners of the oven or stovetop. This small flame is fed by a tube emitting a very low amount of gas. When clogged, the pilot light will go out and will be impossible to relight. The Family Handyman website says that a standing pilot light tube is easily cleaned with a needle. Running the needle through the pilot hole will remove any built-up soot or food debris, allowing the gas to flow freely again. Cleaning the pilot light tube should be performed as a part of regular cleaning and maintenance, especially on older gas stoves.
Clogged Burner Ports
Soot, food debris and dust can all clog the ports on the gas stove burner itself, preventing the ignition system from completing the lighting sequence. The experts at Whirlpool say that wiping the gas lines under the burner with a damp cloth and cleaning the ports with a straight pin will return functionality to the burners. Constant attempts to light the burners when they are clogged can overheat or damage an electric ignitor.
Blown-out Pilot Light
Older gas stoves that use a constant pilot light will not ignite properly if this small flame is blown out by accident. Once you have checked that your oven uses a standing pilot instead of an electric ignitor, the Appliance411 website says that relighting the pilot simply requires a long match. Pilot lights that won't stay lit may indicate a clogged pilot tube or low pressure in the gas lines that feed the flame.
I hope the above helps.....
Good luck.
Posted on Apr 10, 2011
Not getting fire out of the oil
97.
no spark from main coil.
that means blown fuses.
or bad ignitor.
the tests are here (form URL your self)
alldata dot com
Oct 12, 2013 | 1997 Dodge Ram 1500 Club Cab
Where is igniter lacated on rav 4 1998
98? what engine?
the ignitor can be in 3 places on all cars.
1: fire wall. connects to 1 coil, or 2 coils(WS) or 4 COPS.
2: ECU
3 :inside the COPS.
the ignitor changes the induction (spark) coil.
and can be in any of 3 places.
i log in to alldata dot com, so can you (a USA example ONLY)
it has 2 (4pin( Igniters)
so obvious has wasted spark.
power pin, ground pin and 2 , pins to ECU.
it says, in the finder, ignition coils 1and2 with ignitor
in coil finder, and service, it states
remove throttle body to access coils
RTM
see coils, ? see wire they go to one place, the ignitor
follow the those wires, see igniters.
Oct 08, 2013 | 1998 Toyota RAV4
Location ignition control module
there are many possible causes.
no year stated, so.???? generic answer
bad crank sensor (the ECU tells you this if you scan it)
bad cam sensor on some engines.
bad ignitor
bad coil
bad ECU.
or fuse blown.
why not go to alldata dot com and see how yours works.
its all there.
Oct 02, 2013 | Chrysler Pacifica Cars & Trucks
How to replace electric ignitor for outdoor grill?
it may be that the electricity or the spark is connection to different point of the grill, the electricity will spark to the closest point of conductivity.
if you check and each ignitor is sparking , strongly ( so no problem with spark modual), then there may be points in the wireing whichis exposed or more likely where the wireing and the ignitore connects,
you can tape it with electrical tape, then it should see the spark to the burner. if it is sparking, and not to the burner, just means it is sparking to a different point, where the jump is shortest.
Apr 18, 2013 | Cooktops
This is aCG4TDBN (elite with no back burner) aprox 6 years old. The ignitors are starting to go bad. How do I replace them?
First, you need to determine if it is the spark ignitors going bad or the Ignition Module.
If the spark ignitor tips are covered with grease or residue, this will give them the appearance that they're failing. Cotton balls and alcohol, work well to clean the spark ignitors. Also, check the wiring from the spark ignitors back to the ignition module. There may be some wear or even a burn on the wiring. Change the battery in the ignition module. Be sure the new battery is facing the same direction as the old battery, when you install it. Before installing the new battery, check the battery holder for corrosion on the contacts. If you see any, use a Q-Tip and WD40 to remove it.
As far as replacing the ignitors is concerned, you may only have to replace the spark ignitors and not all the wiring. It depends on how the wire is attached to the spark ignitor. If it can be carefully pulled of the bottom tip of the ignitor and then si back on, all you need is the spark ignitor. If not, you'll need the spark ignitor with the wiring attached. All of the wiring, will then have to be fished back to the ignitor module.
More more info on all the parts you may need contact BBQ's Galore 800-752-3085.
I hope this helped you to troubleshoot and determine if any parts do need replacing.
Jun 30, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
The oven won't ignite. I have had igniter replaced 4 times...why do we continue to get this proble
The model number you provied has a missing number at the end so I am using GS56LXSS0 for this example. This unit is using a spark ignitor instead of a Glow Ignitor.
This system also uses a Spark Modual control board to provide the spark to the spark ignitor. The spark modual is a common part that goes bad and could be your problem and is located in the control area part # 9758080
Note : All the spark Ignitors on your Stove are connected to this spark modual and if any of them are shorting anyware this will cause a problem with the spark modual and the amount of spark given to each spark ignitor.
Dec 19, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Kitchen Ranges Logo
185 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
