Question about Samsung WF337AA Front Load Washer
Samsung front loader washer gets about 3 i nches of water over 12 to 14 hour period
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- not closing completely which is its default/no power position. Turn each tap off overnight in turn to see which one is the culprit. It needs replacing ;-0(
Good luck,
John C
Please score this solution accordingly- thanks!
Posted on Apr 10, 2011
What does flashing nf sign means on the samsung front loader
It means "No Fill". NOt enough water is making it into the washer. Make sure your water connections are good and hoses are not kinked.
Jul 24, 2016 | Samsung Energy Star 3.9 Cu. Ft. Front Load...
Tip
Top-Load vs Front-Load Washers - Things to Consider
The traditional top-loader is more comfortable to load and cheaper to buy. High efficiency washers in top-load or front-load models are much more expensive but are water and energy savers, with front-load models having the best energy ratings. Front-load washers have a better spin which leaves less water in the load causing less drying time. High-efficiency models require low-sudsing HE detergent due to low water levels and they require a little more care. They also have more cycles and convenience features than traditional top-loaders. Warranty periods generally are a year regardless of washer style.
on Aug 17, 2010 | Refrigerators
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
Front Loader Humming
Thats normal just the water valve
Dec 15, 2009 | Samsung WF328AA Front Load Washer
What does the max extract feature do
If the washer is removing all of the water from the washer during the spin cycle it is likely working properly. Not an expert but I believe max extract causes the washer to spin for a slightly longer period of time in order to remove more water from the clothes. We use it regularly because our clothes come out to wet otherwise.
May 03, 2009 | Maytag Neptune MAH6500A Front Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Samsung WF337AA Front Load Washer Logo
318 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
