Question about New Home Hunter Charmaine¿ Model : 28190 Brand Fan
I havea loud popping noise about every 45 minutes coming from a ceiling fan that I mounted 2/13/11. this just started about one week ago. Can you help me
    President:
  • 1,515 Answers
Hello, I wish I were there to know what kind of popping its doing? I would set up a ladder or something steady, and with the power off check all of the blades for any cracks or any damage at all. Also, after it has ran for sometime, and you here it pop, kill the switch and grasp the body of the motor to see if it is hot, carefully though. You may have a faulty winding in the motor that has been damaged causing the motor to pop if it has come un wound from the coil and arcing.Keep your eye on it and to be honest, there is not a lot that can go wrong and cause this. When you mounted this fan, did you have to add a piece of 2x4 from joist to joist to have a good strong support? If not, it could be that the electrical box may be popping at times. Anyway, I hope I have given you some ideas to solve this problem. Being that the fan is that new, its hard to believe the motor is popping due to a winding. Check the box and blades, and make sure it is in balance. You will be able to find the cause. Just make sure it's not popping from the electrical box moving every now and then. Check your wiring to make sure you don't have a hot or neutral wire grounding once in a while.
Sincerely,Shastalaker7
Posted on Apr 10, 2011
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
Dell 5100mp projector fan is quiet when doing presentations on table top, but makes noise when ceiling mounted for home theatre. Noise get better after 20-30 minutes, but is just as noisy next time i...
turn it on when sitting on a table right side up. If possible, take the cover off and support carefully nearby the unit. Then slowly rotate the unit upside down and notice when the noise starts to get worse. Have a look at the fan area and see if there is anything that's causing the fan to make a worse noise. perhaps the bearings are getting worn out or something's not as titgh and vibration is being amplified by the fan unit.
Jun 07, 2011 | Dell 5100MP Multimedia Projector
I have the Kenmore refridgerator with the freezer on the bottom, and lately it has been making a loud noise when it comes on. It has been doing this for a week or more, today I noticed that the temperature...
You need to check for the refrigerator level, drain pan, condenser fan, evaporator fan and inspect the compressor mounts for the cause of noise. Any popping or hissing sound is normal on frost free refrigerators.
Good luck
Jul 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My projector is making loud buzzing noises that arent normal.. I just ceiling mounted my projector its an InFocus ScreenPlay 4805 and the bulb has 1500 hours on it. The buzz started after it was on for 30...
If this sound you are describing is NOT constant and is intermittent in nature it is certainly not a color wheel problem. This sound is usually caused by failure of the Lamp cooling fan (the large one)'s Mos-Fet driver chip. Located on the bottom of the main board. These surface mount "chips" do fail and it's a fairly common problem however this is usually (but not always) accompanied by the projector shutting itself down after a few minuets or so as the high temp switch trips off. A color wheel common failure presents in two ways, either all the glass color filters fly off (there are six) and the image is monochrome (black and white) or just one or more of the segments has come off and the result is an imbalance of the color wheel which spins VERY fast resulting in a vibration
that is constant and can easily be felt by placing your hand on the projector. And all of these problems are very easy to repair.
Good Luck!
SagerTronics
Nov 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
Loud popping noise and spark coming from red projector
I would guess you have a High Voltage Leak at the Anode Lead Cap where it Mounts to the CRT. This is not a area to mess with You are better off calling a professional to fix it. It may be a little difficult to confirm if it is a intermittent problem.
Hope this helps,
Skyassoc
Jul 04, 2009 | Hitachi 51F59 51" HDTV Projection...
I have a interminant rather loud chatter every so often, sometimes 10 or more minutes apart. Three months ago when it happened I moved it out and vaccumed and cleaned every thing I could and the noise...
Other tips: please rate my suggestion...
Apr 30, 2009 | Refrigerators
Loud noise when Tv comes on souns like fan.
The loud noise is the color wheel winding down when you turn the TV off. You need to replace the color wheel.
Nov 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Dryers Logo
78 people viewed this question
Top New Home Dryers Experts
Are you a New Home Dryer Expert? Answer questions, earn points and help others
