Question about Philips arcitec 1060 Electric Shaver
The red indicator light has flashed the past couple of days. What does that mean? Also, the shaver doesn't seem to want to click on.......it takes a second or two to begin operating. Do I need to replace it?
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 95 Answers
It's menas that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is philips norelco RQ10 replacement heads.
The red indicator light has flashed the past - 2614e50a-e255-4c83-8062-64bab2311216.jpg
Posted on Sep 11, 2013
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
I have a Norelco arcitec 1050 electric razor and I have lost my instructions. What does it mean when the red light starts flashing (picture of razor heads)?
Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
Aug 15, 2011 | Health & Beauty
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
My device a red blinking light with a dark screen.
The red blinking light can mean a couple of things. First, It could mean that you have a message. If that is not the case, you caould have on the 'LED Coverage Indicator'. The LED Coverage Indicator tells you by having the top light flash eather Green or Red depending on coverage. If you are in a place that has good coverage it wil flash Green but if you have little or no coverage the LED will flash Red. To check if you have this setting enabled, first go to "OPTIONS" on the phone in the full menu. Once there, go to "SCREEN AND KEYBOARD". Click on 'SCREEN AND KEYBOARD" and scroll down will you see the option that says "LED COVERAGE INDICATOR". Click on that and switch it to OFF if it is not already there. Then click the back bottton and click SAVE. That should work. If it doesnt, I would call your phone carrier and ask them.
Feb 19, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Philips arcitec 1060 Electric Shaver Logo
205 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
