Question about BenQ Scanner 5160C
I installed the scanner, no led lights, and when i launch the mirascan6.2 software it appear that the scanner can not be found.Even though, when i plug the usb scanne, windows notifies me that it is connected.Please help me.THX
I have the same prob !..no solution yet !
Posted on Feb 21, 2013
How can i setup launch x431
you can go to here found, there have many details files which you can download.
http://www.careucar.com/wholesale/Brand-launch-x431/
Jan 13, 2014 | Launch Tech NEW X431 Master Diagnostic Kit...
When I press the scan button, the error USB not connected appears even though it is connected.
You will need to install the software that came with the printer on the computer that it is connected to. The software will then run on the computer and "listen" for a command when you press the scan button. What is the make/model of your printer?
Feb 28, 2011 | Computers & Internet
I downloaded software yesterday to make my 3210 all-in One photosmart printer compatable with windows 7 operating sx on my new pc It is printing fine but can't get the scanner to work. My email is...
There are a couple of issues that can cause this. 1) Did you install the full software before you connected the USB cable (if you are using that connection)? If not, did you uninstall the generic software and remove the data cable before installing the software? Try a new data cable and a direct connection if you are using a print server or USB hub. Scanners require bi-directional communication and will fail even when the printer works.
Are you launching the scans from the computer or the scanner? Try launching the scans from the computer first. Remember you need to set the destination button defaults in the HP software and the monitor program needs to be running to see those button presses. Try scanning with Windows Fax and Scan (New Scan) or Paint (File > Import from Camera or Scanner > New Scan).
Navigate to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=439488 and select your OS version (32- or 64-bit Win7) and click Next. Then look in the section Utility - Diagnostic Tools. Download and run the HP Scan Diagnostic Utility. Also check if you need one of the Update patches (there is one for scan files going missing).
If you are using the unit as a networked printer, also try a new data cable. Make sure the router is not dropping packets and that your firewall isn't blocking the incoming signal from the scanner. (Try scanning with the firewall temporarily disabled.)
Check if the unit has a scanner lock and unlock the transport lock if it is in the incorrect position. Check if the lights come on and the unit moves when you try to launch a scan. If the lights aren't coming on or the scan unit doesn't move, the unit probably needs service.
I hope this helps.
Nov 14, 2010 | HP Photosmart 3210 Printer
Launching Scan Software Launches my Browser
Canon Software doesn't work that well. Adobe Photoshop works well with my Canon N656U.
Also, You may need to run an error check on your computer.
Feb 13, 2009 | Canon CanoScan N656U Flatbed Scanner
Launching my scanning software launches my browser, then crash
The setup may be accessing your browser for registration of the product. This could be causing your firewall to stop it as it doesn't recognise the request. You need to allow the programme associated with the product to access the internet.
Feb 13, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
Error in registry
The easy way is to make windows repair itself, this can be done by starting your pc from the windows cd, then when the blue screen appears with 3 options,
..install windows,...repaire,...quite ..F3,
press enter for installation, then F8 to accept, then windows setup will search for installed OS and then asked you to press R to repair it, from this point you can press R and wait while installer delete windows system files the reinstall them without loosing your installed programs.
Dec 10, 2008 | Computers & Internet
Green layer on scanned image from ADF Simplex
What model of scanner are you using? Is it white light based or RGB LEDs (Light Emitting Diodes). Very rarely it may happen that the Red and Blue LEDs are not glowing may be because of loose contact, but this very rare occurence. Try reloading driver software.
S. Mohan
Aug 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Dimage 5400 on an Imac
Try deleting a file called MFSLibInit which the scanner sometimes seems to erroneously create when you launch the software. The file will appear in the dimage folder (you'll find that folder in the preferences folder within the library folder). Then re-launch. This solved the problem on my powerbook but I now have a new MacBook pro and am having the same problem and this is not solving it. Good luck.
Apr 02, 2008 | Minolta Dimage Scan Elite 5400 Film...
Epsom CX7800 Scanner Printer
Windows XP has its own scanning software found within the control panel under scanners and cameras. This appears to provide a more direct method of controlling the scanner because it is part of the OP Sys as opposed to 3rd party scanner software. If the scanner is installed and it appears as an installed option, then try using this approach instead of the actual scanning software.that came with the scanner.
Dec 23, 2007 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
