Question about H&R Block At Home 2010 for PC, Mac
When starting H & R block 2010 I get the following message. No write permisson to the Directory. (See WinFileWriterYimpl::open()) I tried unsntalling the program and installing it again, it did not correct the problem. The error also occurs when trying to start H & R block 2009
  • 75 Answers
Run it in administator mode and see if that works.
Posted on Apr 25, 2011
Error trying to open the file in Word 2007/2010
You might need the Microsoft Office Compatibility Pack. Get it here:
https://www.microsoft.com/en-us/download/details.aspx?id=3
Good luck.
Jan 18, 2018 | The Computers & Internet
Rw 240 scantool, gives the following error message:Could not create directory ...The filemane, directory, or volume label syntax is incorrect.This is my first time using this plotter/scannerRicoh RW 2
Check the folder name & location of the directory at the end of the error message string, then check to see if that directory actually exists and if you (logged in user) actually have full read/write privileges to that directory.
May 08, 2014 | Ricoh - RW-240 Print Controller - 411737
Need to Reconfigure my Microsoft Outlook
The program or your profile may have become corrupted. you can try these methods to see if they will work for you.
Method 1:
Remove your current profile and reestablish it by completing the following:
  1. Close out of MS Outlook 2010
  2. Navigate to the Control Panel
  3. From the pop out menu click on account settings
  4. Click on the Category dropdown menu in the upper right-hand corner and choose small icons
  5. Click on the Mail Icon
  6. Within the Mail Setup Window Click on Show Profiles
  7. Highlight Outlook and Click on Remove
  8. Now Restart machine
  9. Repeat steps 1 - 6
  10. Within the Mail Setup Window Click on Add
  11. Type in Outlook Press OK
  12. Press OK to exit the Mail Window
  13. Close all Open windows and open MS Outlook
  14. Move to the next Method if Method 1 did not work
Method 2:
Repair MS Outlook 2010
  • Press the start menu
  • In the search field type in Programs and Features, press enter
  • With in the Programs and Features windows locate MS Office 2010 and Highlight by selecting
  • From the top menu click on Repair and follow the installation wizard instructions to finish the repair
Let me know if that helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Jul 15, 2013 | Microsoft Office Home And Business 2010,...
System error &H80040111 (-2147221231)
Try installing your .NET frameworks and other Windows related runtimes.Also try re-installing the complete Microsoft Office package
Jan 28, 2012 | Microsoft Office Computers & Internet
I had forgotton my administrator password & log-on using Guest account currently. All the program run needed to passby UAC (User Account Control) permisson. How could i reset it without permisson to...
Hi cheewee6...
Try this solution to your problem
Start your computer
1. Keep pressing "F8" as the laptop computer starts.
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 10, 2011 | Dell Vostro 200 PC Desktop
Hello peeps. I had forgotton my administrator password & log-on using Guest account currently. All the program run needed to passby UAC (User Account Control) permisson. How could i reset it...
Hi cheewee6...
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
Weird folders appearing
those all are garbage folder, which are generated as a result of virus attack on your system, i strongly recomend you to format your main drive and reinstal the windows and this time also instal a powerful antivirus
Nov 05, 2009 | Microsoft Windows XP Professional
Cannot Open DSA.MSC file error
When you install the Administration Tools Pack on a computer that is running Windows XP Professional x64 Edition, the Active Directory Users and Computers MMC snap-in file (Dsa.msc) is installed in the %windir%\Syswow64 folder. Additionally, the computer's file system maps the Active Directory Users and Computers MMC snap-in to the following path: DriveLetter:\%windir%\Syswow64\Dsa.mscHowever, the Active Directory Domains and Trust MMC snap-in incorrectly specifies the path of the Active Directory Users and Computers MMC snap-in as follows: DriveLetter:\%windir%\System32\Dsa.mscWhen the computer's file system tries to locate the Dsa.msc file from within the Active Directory Domains and Trust MMC snap-in, Mmc.exe is run. Mmc.exe is run because the Dsa.msc file is associated with Mmc.exe. When Mmc.exe is run, it uses the following path to locate Dsa.msc: DriveLetter:\%windir%\System32\Dsa.msc DomainPathAfter the Mmc.exe command is run, the Active Directory Domains and Trust MMC snap-in tries to locate the Dsa.msc file. Because the Dsa.msc file does not exist in the %windir%\System32 folder, the error message that is mentioned in the "Symptoms" section is generated.
To resolve this problem, manually copy the Dsa.msc file from the %windir%\Syswow64 folder to the %windir%\System32 folder.
Your hardware manufacturer provides technical support and assistance for Microsoft Windows x64 editions. Your hardware manufacturer provides support because a Windows x64 edition was included with your hardware. Your hardware manufacturer might have customized the Windows x64 edition installation with unique components. Unique components might include specific device drivers or might include optional settings to maximize the performance of the hardware. Microsoft will provide reasonable-effort assistance if you need technical help with your Windows x64 edition. However, you might have to contact your manufacturer directly. Your manufacturer is best qualified to support the software that your manufacturer installed on the hardware.
For product information about Microsoft Windows XP Professional x64 Edition, visit the following Microsoft Web site:
http://www.microsoft.com/windowsxp/64bit/default.mspx (http://www.microsoft.com/windowsxp/64bit/default.mspx) For product information about Microsoft Windows Server 2003 x64 editions, visit the following Microsoft Web site:http://www.microsoft.com/windowsserver2003/64bit/x64/editions.mspx
May 30, 2009 | Microsoft Windows Server Standard 2003 for...
Active directory
hello,
we have a following command option to open active directory:
dsa.msc
thanks,
Sep 30, 2008 | Microsoft Office Outlook 2003 for PC
Not networked properly
Solution To resolve the issue, follow the steps in the solutions below in the order presented. Solution one: Scan from the EWS (Embedded Web Server) Verify that the product can scan and is connected to your network by scanning from the embedded Web server (EWS) on the product. Use the following steps to scan from the EWS:
  1. Print a Network Configuration Page from the product. NOTE: See the product documentation, User Guide, or online resources for information on how to print the Network Configuration Page.
  2. Locate the IP address.
    • Check in the Wired section if the product is connected with an Ethernet cable
    • Check in the Wireless section if the product is connected using a wireless network connection.
  3. Make a note of the IP address found in the appropriate section (wired or wireless); for example, 192.168.1.1.
  4. Open the Web browser.
  5. Type the IP address into the address bar of the Web browser (such as http://192.168.1.1) . Then press Enter . The EWS for the product opens. If it does not open, STOP and click here to check the network connection between the computer and the product (c00047176) (in English).
  6. If the EWS page opened, find the Scan on option.
  7. Click Scan to perform a scanning operation.
  8. If you can scan from the EWS and not from the HP Director/Solution Center or from the product front panel, then continue to Solution two.
Solution two: Check the personal firewall settings When the firewall program is re-enabled after installing the All-in-One software over the network, it may block HP programs or ports required for scanning. If you see pop-up screens asking you to permit access to the network when you try to scan, you should permit access. NOTE: Firewall programs may also block the scanning operation even if they were enabled while installing the All-in-One software. Firewall programs do not always provide messages when blocking access. Follow Step one to allow access to HP program files and ports needed for scanning. Step one: Add programs to the firewall exception list
  1. Open the firewall program.
  2. Add the following files to the Highly Trusted programs list:
    • hpqkygrp.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqscnvw.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqste08.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpzipm12.exe , located in the C:\windows\system32 directory.
    • hpzinw12.exe , located in the C:\windows\system32 directory.
    • hpqtra08.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqthb08.exe , located in the C:\program files\HP\digital imaging\bin directory.
  3. If these files are already added, check whether full access has been granted to them.
  4. Open the following ports on the firewall utility by following the instructions provided by the manufacturer:
    • UDP ports: 161, 427 and 137
    • TCP ports: 9220, 9500 and 9290
Step two: Restart devices on the network After making the changes to your firewall application, turn off the All-in-One, the computer you made the firewall changes on, and your router, and then turn on these devices in the following order:
  1. Router
  2. HP All-in-One device
  3. Computer
Apr 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
H&R Block At Home 2010 for PC, Mac Logo
647 people viewed this question
Top H&R Block Computers & Internet Experts
David Payne
David Payne
Are you a H&R Block Computer and Internet Expert? Answer questions, earn points and help others
