Question about GE Spacemaker JVM1640SJ Microwave Oven
Jvm1631wb004 - What is the size of this model?
Is this model still available for purchase, if not what is the mdl # that replaced it?
Brenda, according to the GE website, that model is no longer available. They do have other models of similar size though. I have included a link to their website for that size microwave. Products from GE Appliances
Nov 17, 2014 | Microwave Ovens
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
May 01, 2011 | Electrolux Microwave Ovens
How do I replace a broken door handle on a GE Microwave JVM1631WB004?
First determine if you can get a replacement handle will you be able to remove the broken handle on your own and install the replacement or will you need the assitance of an experienced repair person.
if you have the tools and know-how to do thihs on your own determine ifyou can get a replacement door handle. Information on contacting GE for parts in Canada can be found here:
http://www.geappliances.ca/parts/index.jsp#3
You could also try their call center: 1.888.261.3055
Make sure you have your complete model number and description of your unit. Was not able to locate information for the model number you provided.
GE Global website can be found here. You may be able to find your model if you check on the website for the country of purchase.
Jan 30, 2011 | GE Microwave Ovens
Crack in GE jvm1631wb004 Door
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
For most models, you can order just the part that's damaged.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jun 07, 2009 | GE JVM1631 Microwave Oven
GE Spacemaker Moldel # JVM1631WB004 Night Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Remove and reinstall door
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Otherwise, you;d have to order the full service manual at the link above.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 28, 2008 | GE JVM1631 Microwave Oven
Hello Guru,
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 15, 2008 | GE JVM1630 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
254 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
