Question about GE WBVH6240F Front Load Washer
My front load washer will not complete a cycle, when it is near the end of the load is doest spin or empty completly
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
If this is the solution please score it accordingly- thanks!
Posted on Apr 10, 2011
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Does not complete the cycle or empty the water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Hotpoint Aquarius WF220 Front Load Washer
My washer will not empty all of the water out on the spin cycle, it does not matter which wash cycle I have put it on. I have even tried the Drain and Spin cycle. I have even taken all of the clothes out...
heatman101
Apr 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Not completing cycle - water left in drum - how do I empty it
hi
yon need to remove filter and clear any debris which is in there and check the pump impeller is turning ok.
regards
Mar 21, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
GE WBVH6240F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
