The pilot light on my daughter's Worcester 240 combi rsf has gone out - how does she re-ignite it?
    President:
  • 1,515 Answers
Hi, I looked up this unit for you and found out it is a hot water system. She needs to get to the main gas valve to light the pilot. This unit has what is called a thermocouple on it that keeps the pilot on, even when the boiler shuts down. Its just a matter of lighting the pilot light. There should be a metal plate with the directions on it at the gas valve to lite it. You will have a knob, more then likely red or black in color on top of the valve. It will say on, off, and pilot. It should be in the on position now. Turn it to pilot. Have some matches with you and a flashlight if you can. You will need to look back into the burner area to where your pilot light will be. The thermocouple is a copper colored tubing that runs right back to the pilot, as it has to get hot from the pilot flame to work. To start, depending on how far back you have to reach with the match, you may need to use a piece of solid cardboard rolled up, a small piece to light it and reach in. Turn the knob to pilot. Now, push down on the knob and hold it down. This lets gas get back to the pilot, so you must keep it down and light it at the same time. Once it is lite, you have to hold it down for at least a minute. Slowly release it, very slow. The flame should then stay on. Once it is on, turn the gas knob to on. With the thermostat set to come on, it will fire up and heat the water. If the pilot will not stay lite after you hold it down for 1 minute, and keeps going out, the thermocouple will need to be replaced. It is the copper line that screws into the gas valve and goes back to the pilot. You can get them at any hardware store for around $6.00. Maybe you can help her install it. It is very simple to do. I believe the pilot just blew out and she will need to light it. Just follow what I have told you, and she will get it lite. Good Luck to you.
Shastalaker7
A/C, & Heating Contractor
Posted on Apr 10, 2011
Connect cm900 to 240 combi rsf
240 volt wiring has two 120 leads, one ground.
Nov 15, 2013 | Water Heaters
THERE IS NOT IGNITION. IT SPARKES BUT WONT LIGHT.
sounds like your not getting gas...maybe a vapor lock,,,,,,,make sure you are compressing the pilot button all the way.....try to listen and see if you hear gas flowing....
Jan 19, 2013 | Bosch Worcester Spark Electrode...
Pilot light ok when release finger pilot goes out
Your thermo couple is bad. Thats the copper tube that goes from the gas valve to the pilot. It senses thats the pilot is lit. Thats not working thats why it goes out. You can get a new one at lowes or home depot for about ten bucks its pretty easy to change just dont kink it when you put it in. It will just plug in at the pilot and screw in at at gas valve.
Jan 11, 2013 | Bosch Worcester Spark Electrode...
I have worcester combi boiler 24CDI RSF, the boiler will not ignite, for the hot water or the central heating, it was working ok, and the red water light is flashing
i think the fan may be stuck. you will need to gain access to the internals of the boiler so a gas safe engineer will need to be employed to do it. if it is the fan, a simple squirt of lubricant will free it and give you anything from a week to a year of trouble free operation but! you will need to get a new fan. Fit a new one as soon as you can as they tend to go at the worst possible time if you dont
Oct 20, 2011 | Combi Centre DX - Mango
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
I have a twenty year old worcester combi boiler with pilot light failure. It relights following instructions and is fine for a week or so then problem arises again, only this time it won't relight at all....
If you are lucky it may just be a worn out thermocouple or maybe a choked pilot jet or the gas valve may have gone faulty and require replacement, if you haven't had the boiler serviced on a regular yearly basis then a service will be required and any other worn parts replaced,fans,pressure switch, thermistors and safety stats are all parts that wear out after a few years, your oher option would be to replace your boiler with a new high efficiency boiler without a pilot, cheaper to run and better for the planet.
Mar 01, 2009 | Combi Centre DX - Mango
Faulty Worcester boiler
we have a worcester24i rsf boiler installed in our mobile home buy the the water temperature seems locked in at a certain temperatutr any idea how we can change this
Oct 19, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
704 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
