Question about Frigidaire ATF6000ES Front Load Washer
Grease, or some substance on clean clothes
After the washer has completed the entire cycle, and the clothes are ready to go in the dryer, I notice dirty lines on the clothes (towels, etc.). The lines (marks) are about 1/8" wide and about 6 - 8" long. If we notice them, we put spot remover on the mark and rewash, which usually gets them clean. If we do not notice the marks and dry the clothes, forget about running them back through the washer.
Thank you for your advice.
Jerry Melendy
  • jgmelendy Aug 07, 2008
    Jerry Melendy
  • alla216 Aug 12, 2008
    I have the same problem. I already cleaned the rubber seal area (eww! it was bad), and thought that took care of it, but my latest load of light colored clothes had about 4 items with these mysterious dirty streaks on them.
  • 876 Answers
You need to thouroughly clean the large door seal in all of its grooves and the inside of the door as well. Just put on gloves and use detergent to do this and rags or pape rtowels. Also make sure the inside of the tub is clean and that you are not overfilling the washer. Good luck.
Posted on Aug 13, 2008
The dryer heats up,it also goes through the entire cycle but the clothes are never thourly dryed.What could be the cause?
Typically it is because lent has built up in the vent tube. Here is a good site that shows you how you can do it yourself: http://www.wikihow.com/Clean-a-Clothes-Dryer-Vent
Sep 04, 2014 | Kenmore Dryers
What should I do to stop washer from putting grease on clothes?
Good Afternoon Bernard,
I understand the washer of your Frigidaire laundry center, model# GLEH1642F, is leaving grease in your clothes. I also see that you noticed the grease in the detergent cup. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine where the grease is coming from to be able to repair your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLEH1642F Front Load Stacked...
Empty the dryer does not squeak but add clothes to it starts up, Frigidaire LEQ6000ES2
Hello David Strobel - Do you notice the black substance after you take the clothing out of the washer or is it after it has been in the dryer?
Dec 09, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Super...
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Washer not draining
Probably the pump filter needs cleaning.
It should be located at the bottom front of washer behind drop down cover, turn anti-clockwise to remove and clean.
May 04, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hard, unidentifiable substance in washer
with almost all front load washers you have to remember to run clean cycles due to moisture in unit and door constantly closed they get mold and mildew along with debris from washing it can leave very strange looking deposits on the front rubber area because it collects these things.Suggest running unit with bleach and no clothes several times to get rid of foreign matter inside and leave door open after to dry interior out overnite and one more bleach cycle in morning and should be good to go after.Refer to manual from this point how often to running clean cycle.
Mar 25, 2009 | Kenmore 42822 Front Load Washer
Maytag Nepturn TL FAV6800 Grey spots/debris on clothing
Hello davidsonrepl,
I was waiting with someone with more experience to post back on your issue. I haven't experienced this issue it but I would not rule out a transmission seal failure causing your oily grey substance in the wash tub. If you want to investigate further you can get the Service Manual from here
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
take a look at page 38 and on and see if you feel OK with a tear down to the transmission.
Feb 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Jul 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Tar-like substance appearing on clothes and washine machine
i havnt seen any flashes on this id look closley at what your putting in the washer as there is nothing in the unit its self as far as mfg that will cause this also try this 1. Open the washer door and remove any clothing or items from the washer.
2. Inspect the gray colored seal/bellow between the door opening and the basket
for stained areas. Pull back the seal/bellow to inspect areas under the seal/bellow.
3. If stained areas are found, wipe down these areas of the bellows using the following
procedure:
a) Mix a dilute solution of liquid chlorine bleach and water (3/4-cup bleach in
1 gallon of warm tap water).
b) Wipe the seal/bellow area with the dilute solution.
c) Let stand 5 minutes.
d) Wipe down area thoroughly with a dry cloth and let the washer interior air dry.
e) Please note:
- Do not use bleach at full strength for cleaning surfaces.
- The use of rubber gloves is recommended when cleaning for prolonged
periods.
4. To begin the clean out cycle, do the following:
a) Open the washer door and remove any clothing or items from the washer.
b) Be sure door is closed.
c) Open the dispenser drawer and remove the detergent divider from the main
wash detergent compartment. See the Use and Care Guide for instructions.
No additives will be added at this time. You will be required to add them at a
later step.
- For Whirlpool Duet, select the “Power” button.
- For Kenmore Elite HE products, move to the next step.
d) Select the “Normal” wash cycle.
e) Select the hottest wash water temperature available, (not all temperatures will
be available).
f) Select the highest spin speed available.
g) Select the additional or 2nd Rinse option (if available).
h) Press and hold the “Start” key for 2 seconds. The door will lock and filling will
begin. NOTE: The water will dispense for a moment, then the door will unlock
and re-lock and the cycle will continue.
i) Once the filling has begun again, open the dispenser drawer and immediately
add 1 cup liquid chlorine bleach to the main wash detergent compartment.
The liquid chlorine bleach should immediately flow through the dispenser.
NOTE: Do not add any detergent to this clean out cycle. Use of more than 1 cup of
bleach per month will cause product damage over time. Addition of bleach without immediately
starting the will cause damage to the product over time
5. Once the clean out cycle has begun, allow the cycle to completely run.
6. After the clean out cycle is complete, leave the door slightly open/cracked to allow
for better ventilation and prevention of future odor issues.
7. If you removed the detergent compartment divider, be sure to replace the divider
to the correct position.
NOTE: If necessary, the clean out cycle may be interrupted by pressing the “Pause/
Cancel” button. This will stop the cycle. A “Rinse and Spin” cycle must then be run to
thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage
to the unit and clothing added to the next cycle.
In addition to the clean out procedure, always do the following to prevent future odor
issues.
1. Use only High Efficiency (HE) detergent.
2. Leave the door slightly open after each cycle to allow for better ventilation and
drying of washer interior.
3. Repeat this clean out procedure only on a monthly basis, if necessary.
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Apr 18, 2007 | LG WM-2277HW Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
366 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
