Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Hello FixYa, I have a problem with my Brother MFC-240C. Everytime I try to print something I get a paper jam error message. I have tried opening the back cover and removing the paper but it still does this everytime. I've tried adding more paper, only loading a few pages, but nothing has worked. Do you have any recommendations to fix it?
  • kmistica Apr 10, 2011
    I fixed it; I didn't check the back of the printer where the cover was loose. Thanks for the help though.
  • 583 Answers
This is not a fix, but a troubleshooting step. After you perform this step, please respond and let me know the outcome.
Take a small stack of paper (less than 50 sheets) and place flat in a refrigerator overnight. After the paper has been in there for at least 8 hours, pull it out and fan it (to remove static cling between the sheets). Place in the printer and see if the paper will feed correctly.
If it does, then your problem is high humidity which is a common cause for paper sticking together and causing paper jams. If it doesn't, then you've probably got a torn piece of paper somewhere in the paper path that is causing a jam. Either way, let me know your results so I can help you troubleshoot your issue.
Posted on Apr 10, 2011
  • Mark Tidwell
    Mark Tidwell Apr 15, 2011
    You stated you checked the back cover in the original help, so I was only going on the information you provided.
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
My mfc 240c always shows paper jam, and nothing found
please printer in open the head couver and check the paper and other
small parts paper in printer and you carteriase out of printer and
check the paper and printer in back side in fixes paper to out and
clean the printer and close the couver is ok and apply the plug printer is on and aply print ok
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Print Unable 4F
The most common cause is jammed or shredded paper. Check for tiny pieces of paper throughout. Hope this helps.
Jul 14, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error 50 after jammed paper on brother MFC-240c
I had this too, I had to open the back of the machine, it is meant to open and pull out and clear the jam (pull out the crinkled paper) but everytime I tried to print again it kept saying that it still had the jam, I opened and closed it several times and it did not seem to register that I HAD CLEARED THE JAM, so what I did was unplug it from the wall and then plug it back in and then it was fine. I wonder if this is AN ACTUAL DEFECT with this machine, if ater a paper jam it cannot detect that it has been resolved without having to unplug it and plug it back in, HOPE THIS WORKS FOR YOU.
Feb 24, 2009 | Brother Multi-Function Center MFC-240C...
Paper jam then not printing
TRY OPENING THE BACK DOOR AND TRY RESEATING THE PAPER SENSOR
Dec 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
May 11, 2008 | Brother Multi-Function Center MFC-240C...
Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
May 03, 2008 | Brother Multi-Function Center MFC-240C...
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
