Question about Hampton Bay Heating & Cooling
Just installed, no power - Hampton Bay Heating & Cooling
    President:
  • 1,515 Answers
No power to this unit, or there is power but its not working?? Can you tell me what type of unit you have, a central unit, split system, window/wall unit, a/c only, free standing?? If there is no power to this unit, go to the power supply to see if you have voltage coming from the line side out to the unit. You may have a tripped breaker, faulty breaker, ect. Please let me no more about your situation, so I can solve this for you. Thank you,
Shastalaker7
A/C, & Heating Contractor
Posted on Apr 10, 2011
How do i install video cards in my emachines ET1352G-03W?
Your machine will accept a PCI-e x16 Graphics card. If you are going to go to high high-end, high-power card, ensure that you have the proper power connectors for the card. Mainstream video cards are powered from the PCI-e slot itself. Also, be advised that your machine only has a 220W power supply, so high-end cards may draw too much power from an already anemic source.
To install the new card, simply power off the PC and unplug it. Open the case and locate the PCI-e slot (closest to Power Supply). Take out the proper blank at the rear of the machine to allow the card to be installed. Install the card and secure it with a screw (or whatever means the case provides). Hook up the card's power connector (if equipped). Secure the case. Move your monitor's cable from the onboard video connector to the one on the new card. Power up the PC and watch the bootup. The Operating System should detect the new graphics card and will install, at a minimum, a generic driver for it. To install the drivers supplied with the card, install the CD/DVD and run the install setup program.
Dec 09, 2013 | Computers & Internet
I have installed a new motherboard in an acer case. The power cable from the switch on the front of the case will not connect to the board. Can anyone help? Thank you
You should read the motherboard manual, for cabling:
1. Power SW
2. Reset SW
3. HDD led
4. Power led - and power led +
5. Speaker
Cabling scheme, also written on the motherboard.
If the Power SW not installed the switch on does not work.
If the Reset SW not installed the switch reset does not work
If the HDD led
not installed the hard drive light (red) is not lit
If the Power led (+/-) not installed the power light (yellow) is not lit
If the Speakers are not installed, when the computer is on the beep sound is not heard.
I hope this information helps.
Oct 15, 2011 | Computers & Internet
I need to find out how to remove the power steering pump on a 2006 pontiac grand prix 3.8L
Power Steering Pump Replacement
Removal Procedure
1. Remove the accessory drive belt.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Remove the tire and wheel assembly.
4. Disconnect the power steering pressure hose from the power steering pump.
5. Disconnect the power steering return hose from the power steering pump.
6. Disconnect the harness connector (4) from the power steering pump (1).
7. Remove the power steering mounting bolts from the power steering pump.
8. Remove the power steering pump from the engine.
9. Remove the power steering pump pulley from the power steering pump.
10. Remove the power steering pump reservoir from the power steering pump.
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump.
2. Install the power steering pump pulley to the power steering pump.
3. Position the power steering pump to the engine.
Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts.
Tighten the bolts to 25 Nm (18 ft. lbs.).
5. Connect the power steering pressure hose to the power steering pump.
6. Connect the power steering return hose to the power steering pump.
7. Install the harness connector (1) to the power steering pump (4).
8. Install the accessory drive belt.
9. Fill the power steering system with fluid.
10. Bleed the power steering system.
11. Operate the power steering system and inspect for power steering system leaks.
*This originally came from abauto
Mar 24, 2011 | 2006 Pontiac Grand Prix
How to replace power steering pump impala 2000,engine 3.4
1. Place a drain pan under the vehicle.
2. Remove the accessory drive belt from the power steering pump pulley. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
5. Remove the power steering pressure line from the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L)
6. Remove the power steering return hose from the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Remove the power steering pump mounting bolts from the power steering pump.
8. Remove the power steering pump assembly.
9. Remove the power steering pump pulley from the power steering pump. Refer to Power Steering Pulley Replacement.
10. Remove the power steering pump reservoir from the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
1. Install the power steering pump reservoir to the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
2. Install the power steering pump pulley to the power steering pump. Refer to Power Steering Pulley Replacement.
3. Position the power steering pump assembly to the engine. Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts. Tighten the power steering pump mounting bolts to 34 Nm (25 ft. lbs.).
5. Install the power steering pressure line to the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L).
6. Install the power steering return hose to the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
8. Lower the vehicle.
9. Install the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L
10. Fill the power steering system. Refer to Refilling the Power Steering System.
11. Bleed the power steering system. Refer to Bleeding the Power Steering System.
12. Inspect the power steering system for leaks. Refer to Steering and Suspension Leaks.
13. Remove the drain pan from under the vehicle.
You may want to take it to the dealer or other repair shop. It is very difficult and will consume a major portion of your day.
Nov 28, 2010 | Car Audio & Video
Cant find were to put powersteering fluid
Power Steering Pump Removal & Installation 3.8L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Place a drain pan under the vehicle.
  3. Remove the accessory drive belt from the power steering pump pulley.
  4. Raise and safely support the vehicle.
  5. Remove the right front tire and wheel assembly.
  6. Remove the hoses from the power steering pump.
  7. Remove the mounting bolts and the power steering pump from the engine.
  8. Remove the reservoir and pulley from the pump if necessary.
To Install:
Power steering pump removal/installation (3.8L engine) gm-08-38-480.gif
  1. If removed, install the power steering pump reservoir and pulley on the power steering pump.
  2. Position the power steering pump to the engine and install the mounting bolts. Tighten the bolts to 25 lb ft (34 Nm).
  3. Install the pressure and return hoses to the pump.
  4. Install the right front tire and wheel assembly.
  5. Lower the vehicle.
  6. Install the accessory drive belt.
  7. Fill and bleed the power steering system.
  8. Inspect the system for leaks.
  9. Remove the drain pan from under the power steering pump area.
3.4L Engine To Remove:
  1. Place a drain pan under the power steering pump.
  2. Remove the coolant reservoir.
  3. Remove the pulley from the power steering pump.
  4. Remove the wiring harness near the power steering pump and place it out of the way.
  5. Disconnect the fluid hoses from the power steering pump.
  6. Remove the mounting bolts from the power steering pump and remove the pump.
To Install:
Power steering pump removal/installation (3.4L engine) 88008g71.gif
  1. Position the power steering pump assembly to the engine and install the mounting bolts. Tighten the mounting bolts to 25 lb ft (34 Nm).
  2. Install the wiring harness in its original position.
  3. Install the pulley on the power steering pump.
  4. Install the coolant reservoir.
  5. Fill and bleed the power steering system.
  6. Inspect the system for leaks.
  7. Remove the drain pan from under the power steering pump.
Sep 18, 2010 | 2000 Chevrolet Impala
Where is the power steering dipstick
Most power steering pumps are driven by the serpentine belt and should be in plain view when the hood is open.The following shows how to remove and replace the power steering pump and might give you a clue if not in plain sight. My dad's 1998 Ford Taurus has it nearly on top, but they could have changed things in the mean time: Power Steering Pump Removal & Installation Power Steering Pump (2V) To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the accessory drive belt.
  4. Remove the alternator.
  5. Drain and remove the radiator coolant recovery reservoir.
  6. Position a drain pan under the power steering pump underneath the vehicle. Disconnect the hydraulic pressure and return lines and allow to drain.
  7. Remove the idler pulley from the power steering pump support.
  8. Remove the belt tensioner.
  9. Remove the bracket mounting bolt located under the belt tensioner mounting.
  10. Remove two retaining nuts from the bracket mounting studs. Remove both mounting studs, and pull off the power steering pump support with the pump attached.
  11. Clamp the pump support bracket in a suitable vise.
  12. Remove the power steering pump pulley from the pump shaft using Pump Pulley Remover T69L-10300-B, or equivalent. Remove the three bolts retaining the power steering pump to the power steering pump support and remove the power steering pump.
To Install:
NOTE: The pulley must be installed within 0.010 in (0.25 mm) flush with the power steering pump shaft.
  1. Install the power steering pump to the power steering pump support. Tighten the mounting bolts to 18 ft-lb. (25 Nm).
  2. Install the power steering pump pulley using Steering Pump Pulley Replacer T65P-3A733-C, or equivalent; the pulley face must be flush within 0.010 inch (0.25mm) of the pump shaft.
  3. Install the power steering pump/pump support and torque nuts/bolt to 24 ft. lbs. (33 Nm).
  4. Install the bracket mounting bolt located under the belt tensioner mounting.
  5. Install the belt tensioner.
  6. Install the idler pulley to the power steering pump support.
  7. Connect the hydraulic pressure and return lines.
  8. Install the radiator coolant recovery reservoir.
  9. Install the alternator.
  10. Install the accessory drive belt.
  11. Fill the power steering reservoir with power steering fluid.
  12. Connect the battery ground cable.
  13. Run the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Power Steering Pump (4V) and SHO To Remove:
  4. Drain and remove the radiator coolant recovery reservoir.
  5. Position a drain pan under the power steering pump. Disconnect the power steering pump reservoir hose and allow it to drain.
  6. Using Pulley Remover T69L-10300-B, or equivalent, remove the pulley from the power steering pump shaft.
  7. Disconnect the pressure hose from the power steering pump and allow it to drain.
  8. Remove the power steering pump retaining bolts and the pump.
To Install:
  1. Install the power steering pump and tighten the bolts 15–22 ft. lbs. (20–30 Nm).
  2. Connect the pressure hose and secure the clamp.
  3. Using a Steering Pump Pulley Replacer T65P-3A733-C, or equivalent, install the power steering pump pulley: the pulley face must be flush with the pump shaft or within 0.010 inch (0.25mm).
  4. Connect the power steering pump reservoir hose.
  5. Install the radiator coolant recovery reservoir.
  7. Fill the power steering reservoir with power steering fluid.
  8. Connect the battery ground cable.
  9. Start the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Jul 22, 2010 | 1996 Ford Taurus
Need to replace high pressure power steering hose on 2004 Monte Carlo SS. Need tips to effectively do the job myself. Tools needed, tricks to make the job easier, what not to do...etc. Thank yiou so much...
Power Steering Line/Hose: Service and Repair
Pressure Hose
Power Steering Pressure Pipe/Hose Replacement (3.8L)
Removal Procedure
2. Remove the accessory drive belt.
5. The power steering pressure hose is the lower hose at the power steering gear.
Remove the power steering pressure hose from the power steering gear.
6. Remove the power steering pressure hose from the power steering pump.
7. Remove the power steering pressure hose from the clamps on the power steering gear.
8. Remove the power steering pressure hose from the vehicle.
1. Install the power steering pressure hose to the vehicle.
2. Install the power steering pressure hose to the clamps on the power steering gear.
3. Install the power steering pressure hose to the power steering pump.
^ Tighten the fitting to 27 Nm (20 ft. lbs.).
4. Install the power steering pressure hose to the power steering gear.
^ Tighten the pressure hose fitting to 27 Nm (20 ft. lbs.).
5. Install the tire and wheel assembly.
6. Remove the drain pan from under the vehicle.
7. Lower the vehicle.
9. Fill the power steering system with power steering fluid.
11. Inspect the power steering system for leaks.
Sep 15, 2009 | 2004 Chevrolet Monte Carlo
2004 Pontiac Grand Prix V6-3.8L VIN 2
Power Steering Pump: Service and Repair
NOTE: The content of this article / image reflects the changes called out by TSB: 05-02-32-004.
Removal Procedure
Sep 07, 2009 | 2004 Pontiac Grand Prix
Changing power steering pump
Power steering pump special tools
To Install:
Jun 28, 2009 | 1999 Ford Taurus
98 corvette 5.7 eng., harmonic balancer needs replacing!
Crankshaft Balancer: Service and Repair
REMOVAL PROCEDURE
1. Disconnect the negative battery cable.
2. Release the accessory drive belt tensioner (3).
3. Remove the drive belt (5) from the engine.
4. Remove the power steering gear from the vehicle.
5. Remove the starter motor.
6. Remove the power steering cooler bolts from the front crossmember.
7. Remove the power steering cooler from the front crossmember and reposition.
8. Release the air conditioning (A/C) belt tensioner (10).
9. Remove the A/C drive belt (1) from the engine.
10. Remove the crankshaft balancer.
INSTALLATION PROCEDURE
1. Install the crankshaft balancer.
2. Install the A/C drive belt (1) to the engine.
3. Install the power steering gear.
4. Install the power steering cooler to the front crossmember.
5. Install the power steering cooler bolts.
^ Tighten the power steering bolts to 11 Nm (97 inch lbs.)
6. Install the starter motor.
8. Install the accessory drive belt (5) to the engine.
9. Connect the negative battery cable.
^ Tighten the negative battery cable bolt to 15 Nm (11 ft. lbs.).
10. Program the Transmitters.
May 11, 2009 | 1997 Chevrolet Corvette
Heating & Cooling Logo
59 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
