Question about Lexmark X1270 All-In-One InkJet Printer
My printer keeps stating printer cover open when it is closed please help
  • Official Brand Answer
  • 3,344 Answers
Try to remove the sheets of paper from the feeder. Open the printer cover and remove your cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Make sure they are properly inserted and secured. Load some paper. Check for the error again.
Posted on May 03, 2011
SOURCE: printer cover open error message
Thanks but this suggestion didn't work.
Posted on Jan 04, 2008
  • 726 Answers
SOURCE: problem with my Canon Pixma MP500
i searched error 1851 and all it said was priter cover open due to
the little clip inside is not touching any more
maybe it broke of
on the top of the lid or were it closes you will see it go in u should try to see if its connecrting with the other one at all
Posted on Jul 03, 2008
checkitright
  • 1362 Answers
SOURCE: Back cover open message
there isa switch that is not being activated, open each door there is a small hole that have a switch , put a pice af paper in and activate the switch
Posted on Sep 02, 2008
Scott Ellin
  • 558 Answers
SOURCE: lexmark P3150 says cover is open
May be the cartridge not fitted properly.
Also try to unplug the printer during PC on. and then replug it.
Try to power off printer, restart PC and disconnect USB, then connect after restart PC.
Let me know if you need further help.
Posted on Oct 04, 2008
  • 5 Answers
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Posted on Dec 18, 2008
Keeps saying cover is open/ please close the ADF cover
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 08, 2016 | Office Equipment & Supplies
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
Why I got the message "close cover - upper cover open" ?
There is a sensor on the front left side usualy that detects the cover open or closed state. Check it maybe you made a mistake at assembling it or something came in between and the sensor can't detect it.
Aug 30, 2014 | OKI B4600 Laser Printer
The printer won't print. it keeps stating the front cover is open and the orange light appears. what should i do?
there may be an other blockage.
try opening all covers, and the paper tray.
remove the cartridge and check there is not paper stuck in the printer.
replace the cartridge, the paper tray and close all the covers again.
then press the start button to reset the printer then it should work again.
I hope this was helpful
Jan 11, 2011 | HP LaserJet 1020 Printer
Keeps stating cover open close cover
Hello my friend.First check the Switch activator (hangs down on left side of Top Cover),second check output voltages on the low voltage power supply and if has problem replace the high voltage power supply.Also you can try replace system cable but if its the error still appears its more like a hardware problem like the system board and you must replace it or take your printer to a repair service but i think you may accidentally push the switch or broke it somehow.
Feb 11, 2010 | Lexmark X125M All-In-One Printer
The inner cover (flap in front of cartridges) is closed but the following sign keeps reappearing "inner cover is open. Close the inner cover and press ok".
When the message shows means inner cover sensor is faulty so it cannot detect inner cover state correctly. Try to clean the contact sensor with contact cleaner is good idea since it sometimes an oxidation occurs. Many times I success fix the problem like this.
Regards,
PrinterClinic
Jan 03, 2010 | Canon Pixma MP500 All-In-One InkJet...
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Top cover does not seem to close, and keeps stating that its open, when it is closed.
Your printers top cover is closed. Its generating error just because of faulty sensor. You require to change the sensor. If you are assured that you can do it yourself with our guidence then kindly comment back, or else simply take it to a technician.
Aug 24, 2009 | HP DeskJet 5652 InkJet Printer
Printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
