I have a ford fiesta 1996 ghia uk model and when you turn the ignition on the temperture gauge goes right over to the red when the engine is cold or not and never moves untill the engine is switched off? can you help:)
    Scholar:
  • 133 Answers
It sounds like either the sensor or wire has shorted out. If you can get to the back of the gauge, try disconnecting it, it should drop. Next, If you can find it on the block, try disconnecting the sensor wire for a test. It is usually the sensor though.
Posted on Apr 10, 2011
1996 fiesta ghia diesal no glow plug light
No power to the glow plugs means no power to the light also. You have a bad fuse or connection to the glow plug relay. Fix that and your good to go. Has nothing to do with your indicator lights on either side of dash. Glow Plug power indicator is labeled THAT and only that.
Jun 25, 2017 | 2000 Ford Focus
00 ford fiesta,, heaters,electric windows and indicators not workin, fuses and relays seem good??
have exact same problem myself checked all fuses they are fine & my car is a ford fiesta yr 2000 model Ghia gonna have a look at the 50amp fuses
Any1 else out there have a possible solution. If this 1 dont work
Dec 22, 2009 | 2000 Ford Focus
Ford galaxy 1996 v6 ghia x warning light at temp gauge flashes all the time
If this is a red flashing light beneath the temperature guage it means that you do not have enough coolant. Top up the large white ball shaped reservior at the right hand side of the engine compartment just behind the battery.
Oct 28, 2009 | 2006 Ford Laser
Car cut out while driving and engine now rattles
change distributor cap and rntar button
Aug 06, 2009 | Ford F Cars & Trucks
Ford fiesta,1996,petrol,fails to start.
either your fuel pump relay or the safety shut off switch
Jul 02, 2009 | 1996 Ford Escort 4 Door
Ford fiesta ghia 1998 model central locking key
This is a common problem after changing the Key Fob battery.
The solution is to remove the fuse feeding the Cental Locking for 10 minute...Replace then all should work fine
Nov 30, 2008 | Code-Alarm Code Alarm Transponder
Ford fiesta transponder problem
I have a 2002 fiesta and recently it has been stopping on eac failure and then the imobiliser light keeps flashing and the car wont start not even turn over ha any one got a solution for this?
Thanks llinos
Nov 01, 2008 | Code-Alarm Code Alarm Transponder
Temp gauge
Sounds like a faulty temp sender or gauge, if it does this from cold
Sep 15, 2008 | 1992 Ford Festiva
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
