Question about Tristar Vacuums
I need to take the canister apart to screw the filter housing back in place. I can't figure out how to take the canister apart or another way to screw the filter housing back in place.
  • jameswalk Apr 10, 2011
    The vacuum is an EX20 Canister. I need to reattach the filter basket that contains the exhaust air filter. It is held oin with 2 bolts and nuts. I think you have to take the canister apart in order to attach it but I can't figure out how to take the canister apart, unless it is under the large rubber bumper that circles it.
    If you can tell me how to take the canister apart, I can probably reattach the basket. Unless there is another way to do it.
    Thanks
    Genius:
  • 1,739 Answers
You did not identify your model and the TriStar website does not provide manuals. They do have a FAQ page which does provide some illustrated guidance which may be helpful. See here:
https://www.tristarvacuumscanada.com/faq.php
If this does not assist in resolving your problem reply back with your specific model number.
Posted on Apr 10, 2011
Tip
How to Replace The Cord Reel in a Miele Canister Vacuum Cleaner
Ok, so you need to replace the cord reel on a Miele Canister Vacuum, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy a new Miele series cord reel for your particular model.
Here are links to all of the Miele cord reels if you haven't already purchased one.
Miele Cord Reels & Rewinds for All Brands
So once you have the cord reel, you'll need either a Phillips head screw driver for the older Miele models, or a T20 Torx Screwdriver for the newer models. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure is identical to most Miele canisters . You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter cartridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher position, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and components that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you,
Chris J.
GoVacuum
on Apr 07, 2010 | Vacuums
How do i replace the hepa filter on a dyson dc18? I removed it and now I cannot put it back on.
It is very simple to change the filter and re-attach the canister. Once you have removed the main canister (the one that has the washable filter) you should see the plastic canister, which houses the Hepa Filter. 1) To make life easy, turn your vacuum around, so you are now looking at the back (where the hose and wand are). 2) Remove the hose and wand as you normally would, if you were going to use them. Just lay it on the floor. 3) Now that they are out of the way, you should see the grey plastic holder, towards the bottom (approx 6 inches above the red release peddle for the vacuum. It is attached to the vacuum with only 2 Phillips-Head screws, and was used to keep the hose in place. 4) Use a screwdriver to remove the screws (one one each side). Once it's removed you should easily beagle to change the Hepa Filter. NOTE: Pay attention to where the 4 inverted latches on the canister are, and pay special attention to the fact that there is an extra latch on the canister, which faces the opposite direction of the others. It is this latch on the canister, which must be located through the back handle of the vacuum, since this was the main latch that was secured by the grey hose piece, which you first removed. 5) To reassemble the canister, line up the clips,especially the one that I just mentioned, and make sure the canister is flush against the base. 6) Now, reattach the hose securing piece that you originally removed, and the Hepa Filter and plastic canister should now be fully secured. 7) Place the hose and wand back into their original position and you should now be ready to vacuum. I hope this was helpful. S.I. Educator
May 29, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
My Miele solaris will not turn (it's plugged in and no power)
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello There,
Usually when a Miele canister just stops working all of a sudden, it's a lot of the time caused by the cord reel going bad. The internal cord reel has a metal spring that's used to get power from the cord, to the rest of the vacuum. Over time this spring starts to loosen, and eventually will get so loose that it will no longer transfer the electric current. This is the most common problem that I we see on Miele canisters. The good news is that this repair is fairly simple to diagnosis and repair.
In order to test and see if the cord is the problem, rewind the cord all the way back into the canister, and move the canister to the closest wall outlet. Now only pull out the cord far enough to plug it into the wall. With the vacuum plugged in, use one hand to slowly pull the cord reel out of the canister, and use the other hand to to continuously push the main on/off foot switch pedal on and off, on and off while you're pulling the cord out with your other hand. Does the vacuum motor make an sound like it's starting up, or does the motor come on at all while you're doing this? If it makes a noise like it's trying to start, this means that your cord reel is bad and needs to be replaced. If you don't hear anything while you're doing this, it still may be that the cord reel is bad, but it also may mean that either the switch or the motor could bad. In my 10 years of fixing Miele canisters however, I find that probably 70% of the time it's the cord reel that needs to be replaced.
If you need to purchase a cord reel to try and replace it to see if this fixes it (don't worry, we have an excellent return policy if it's not the problem) , here's a link to the exact cord reel for your Miele:
Miele Cord Reel For S500 Series Models
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bot So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
Thank you so much,
Chris Jones
GoVacuum
Apr 07, 2010 | Miele S514 Solaris Bagged Canister Vacuum
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Thank you very much,
Chris J.
GoVacuum
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Hep! My 3 month old Hoover Mach 5 doesn't pick up!
What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Feb 06, 2008 | Hoover Commercial C1660-900 Bagless...
Vacuum got left in the rain, can't get housing apart
Remove any screws you see on the top rear panel. Take off the filter to reveal another screw. The control panel across the back look between the lid and that panel, there is another screw there. On the very back there is a black strip that helps hold the top panel on. Then the top panel will come off.
Jan 22, 2008 | Miele S251 Flamenco II Bagged Canister...
Problem with motor; need to open the motor compartment
The top piece near the back comes off, use a screw driver to pry the corners out then it will come off. Then you can get to the 2 screws holding the motor housing off. When you put it back on, it just snaps in place.
Oct 24, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
60 people viewed this question
Top Tristar Vacuums Experts
JoeVacs
Thatvacguy.com
Are you a Tristar Vacuum Expert? Answer questions, earn points and help others
