Question about Apple iMac Desktop
Hello my problem is that my desktop on my Imac is bigger than before I mean that it is from 100 % to 150 % bigger.Hpw can I turn it to normal desktop size? Ghafoor Thank you
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
I think what you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key and move your finger on the mouse scroll button back. Hope this helps.
Posted on Apr 10, 2011
Imac start up problem
Hope you can access another computer.
Search box. Type in how to reset an iMac
Switch off, hold down command+R keys and turn on. This is a complete reinstall factory settings. You will lose all your saved data. Sorry, hope it solves
Mar 15, 2014 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
My imac got start up problem
Get your mac repair as there is a problem called boot crash.
Mac desktop stop at apple loading screen how do i fix this
Try to force quit the Applications
  1. Go to the top right part of the screen and click on the Apple logo.
  2. Click "Force Quit"
  3. Select the Application you are in or all of them and for each click "Force Quit"
If this doesn't work try to restart your iMac
  1. On the back of your iMac locate the power button in the bottom left.
  2. Hold down the button and then the iMac should turn off.
  3. After a minute or so, try to turn the iMac back on again, it should be operating normally.
Mar 23, 2011 | Apple eMac Desktop
My desktop was turned off for a couple of months, and when i tried turning it on a file folder with question mark is flashing in the middle of the screen. what do i need to do?
That folder with the question mark means the computer can't find the operating system. This normally means one of two things: either your hard drive has gone bad, or your operating system has gotten corrupt, or a combination of the two. If you have the original install discs, you can boot into them and try to repair it that way- if that doesn't work, you'll most likely need to change the hard drive.
Feb 14, 2011 | Apple iMac 17" Desktop
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
My display is sooo big that i can't really see the whole page. I held down the command button while rolling the ball on my mouse and my screen got bigger and now I can't get it back to normal.
Do the same but roll the ball the other way.
Alternatively, open system preferences, go to universal access and turn Zoom off. Or on the keyboard press "Alt Command -" all at the ame time.
Sep 24, 2009 | Apple iMac 24" Desktop
My iMac G5 1.8 GHz 2GB ram computer desktop
Hello
If you can run it in safe mode, that means that you have an extension problem. I had most of the time problems with the ATI extensions.
First of all try too boot on another account, an new one would be good, to check if this is not account related.
Secondly i would reinstall the system (a clean install would be good, tough you can try an archive-install)
Thirdly if it isnt fixed I would delete all ATI extensions instead of the one that your graphic card uses. to delete: go to /System/Library/Extensions .
Hope that helps
Jul 30, 2009 | Apple iMac G5 Desktop
No output from Keyboard
Hello, Please reboot the computer in "safe mode" holding the shift key at startup. This will deactivate temporarily your extensions. If the keyboard works in safe mode, then go to the apple menu, system preferences, and accounts. Add a new account, reboot and log into your new account. If it still works, then that means that you have a corrupted preference Best regards
Jun 09, 2009 | Apple iMac 24" Desktop
Cant reboot appel imac need help
hold down the power button on the back of the imac until it turns off unless you mean those imac g3 the ones with colors you use the keyboard's power button
Apr 29, 2009 | Computers & Internet
Apple iMac Desktop Logo
63 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
