Question about Dell Inspiron 9100 Notebook
Black lines across top of screen with a coloured stripe at right hand side
  • 805 Answers
At first, please check your monitor dimension and your monitor dpi. please set your dpi 16 bit and 60 hz. after doing that but unfortunately you don't get result then i think its your notebook lcd problem. as a result please consult with a professional technician or better if you have warranty then go to your vendor servicing center. thanks
Posted on Apr 10, 2011
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Panasonic TH-42PX70B plasma tv vertical very this coloured lines in band about thrd of way across screen from right hand edge what is thesolutionto fix this problem
Sounds like COF (Chip On Film) strip fault. Check this link for more details. There is illustrations [screenshots] and reasons to plasma displays. Check it out, and compare them with your TVs fault. Pull up older posts there.
Mar 07, 2013 | Televison & Video
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Dell Inspiron 9100 Notebook Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
